Guess........
Old May 1, 2010 | 10:15 PM
DrX's Avatar
DrX
Default Guess........
Guess which engine mount says "Made in Korea"
Old May 1, 2010 | 10:44 PM
BlownChevy's Avatar
blownerator
25 Year Member
The one on the left?....got two of them on Friday.....Right from the dealer.
Old May 1, 2010 | 11:16 PM
DrX's Avatar
DrX
Actually, it was the other one that came in a box that said Korea on it- the one with the crappy rivets and thinner metal. The new, new one came from a dealer, but I didn't see what kind of box they came in.
Both right and left mounts were in the same condition. Both were nearly new. Not sure how they could pull apart like that when the pieces are clamped together with a bolt when installed??
Old May 1, 2010 | 11:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
sweet!
Old May 1, 2010 | 11:45 PM
budhayes3's Avatar
PT's Slowest Truck
Twin TVS 1900 LSX 427, Custom 14 bolt SF Rear and lots more.
Bolt schmolt, Twin TVS win
Old May 2, 2010 | 12:30 AM
Bigredmariner's Avatar
Too much powa.
Old May 2, 2010 | 11:38 AM
MikeGyver's Avatar
"Nearly new"? That makes me think that the junkyard ruined them when they lifted the engine with their payloader and forgot to unbolt the mounts.
Old May 2, 2010 | 07:22 PM
DrX's Avatar
DrX
By "nearly new" I mean that they only have about 100 miles on them. They were brand new, out of the box, when I installed them.
Old May 3, 2010 | 12:33 PM
BigKID's Avatar
Is the rubber center torn in the one that is severely out of shape?
Proof that the aftermarket should make us some stronger poly mounts.
Old May 5, 2010 | 03:17 PM
DrX's Avatar
DrX
No, the portion of the mount that bolts to the frame is not connected to the rubber- it can slide around on it. The GM mounts, at least my old ones, had a piece of the rubber that fit into that portion to prevent it twisting like that.
The GM mounts do appear to be a little stronger overall. I have looked, but have not come across anything better.
Here is the aftermarket mount after I straightened it out by just twisting it by hand. The rubber looks good.
