Which guages work with column pod?
Old Jan 14, 2005 | 08:34 AM
Default Which guages work with column pod?
Are there any guages out there that will hook directly into factory wiring such as tranny temp wiring. I know several of you have installed a tranny temp guage. The performance shop around here says I'll have to tap into a line or the pan, something about the voltage in the wire is different than what the guage reads.
Also want an A/F guage or fuel pressure guage to monitor when using nitrous. Is there factory wiring I can use or will this guage also need to be piped in?
Let me know which brand you all are using, thanks.
Old Jan 14, 2005 | 09:44 AM
ttt!!
Old Jan 14, 2005 | 10:23 AM
GREGGO's Avatar
Tranny temp....just change the cluster. As far as I know, the tech is right about the voltage. On the rest. it's pretty simple. Just follow the instructions. You will have to wire them yourself. Iwouldn't worry about an A/F gauge, they are only as good as your rear 02 sensors.
Old Jan 14, 2005 | 10:30 AM
Ya, I should change the cluster then I it would also show a higher mph but I have the platinum guages I paid over 100 for I don't want to throw away. Looks Like I'll be doing some more modding and pipping as if i don't already have enough wires going throughout the truck.
Old Jan 14, 2005 | 10:41 AM
ThunderZ28's Avatar
12 Second Club
just run one wire from an Auto Meter guage, and tap in to the plug above the shift linkage.+ a 24v wire to the ignition, and a ground wire.
my guage is right on the money on temps.. checked out with my EFi live..
Old Jan 14, 2005 | 02:43 PM
thank you 01Thunder.
AUTOT3K
Aug 16, 2015 06:21 PM
pupi305
Aug 13, 2015 03:48 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
maxspeed05V
Jul 19, 2015 07:08 PM
1320Chicken
Jul 14, 2015 10:58 PM
