Which guages work with column pod?
Are there any guages out there that will hook directly into factory wiring such as tranny temp wiring. I know several of you have installed a tranny temp guage. The performance shop around here says I'll have to tap into a line or the pan, something about the voltage in the wire is different than what the guage reads.
Also want an A/F guage or fuel pressure guage to monitor when using nitrous. Is there factory wiring I can use or will this guage also need to be piped in?
Let me know which brand you all are using, thanks.
Tranny temp....just change the cluster. As far as I know, the tech is right about the voltage. On the rest. it's pretty simple. Just follow the instructions. You will have to wire them yourself. Iwouldn't worry about an A/F gauge, they are only as good as your rear 02 sensors.
Ya, I should change the cluster then I it would also show a higher mph but I have the platinum guages I paid over 100 for I don't want to throw away. Looks Like I'll be doing some more modding and pipping as if i don't already have enough wires going throughout the truck.
just run one wire from an Auto Meter guage, and tap in to the plug above the shift linkage.+ a 24v wire to the ignition, and a ground wire.
my guage is right on the money on temps.. checked out with my EFi live..
AUTOT3K
Aug 16, 2015 06:21 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
maxspeed05V
Jul 19, 2015 07:08 PM
