GTO setup in a 99 Silverado
Old Jun 9, 2006 | 10:31 AM
Bullhead00's Avatar
Default GTO setup in a 99 Silverado
I've been thinking about this for a while now. I was going to see what you guys thought about or have heard about putting an engine (LS2) and auto tranny (4L65E) out of a 2005 GTO into a 1999 Silverado. Are there any known issues with doing this swap? Would there be anything preventing me from doing a straight up swap?
Old Jun 9, 2006 | 01:02 PM
Bullhead00's Avatar
I meant to add that vehicle I'm wanting to do the swap in is the one in my sig. 1999 single cab 2WD 5.3L. Any advice is greatly appreciated!
Old Jun 9, 2006 | 01:55 PM
Dave68RT's Avatar
i bet it'll fit like a dream
Old Jun 9, 2006 | 02:25 PM
custom 68's Avatar
the oil pan is different the GTO is a front sump so that would have to change. I think some of the sensors are also located differently. I also assume the connectors to the injectors and other sensors are different you would have to swap them as well, physically the block is teh same size I believe.
Dave
Old Jun 9, 2006 | 02:57 PM
silver-mod-o's Avatar
Hunt&Fisherator
something tells me that it will be pretty quick...
Old Jun 9, 2006 | 03:42 PM
i think it would be just like to the standard 6L swap that everyone else seems to be doing. should fit fine just have the harness things to take care of and go with truck oil pan
Old Jun 9, 2006 | 07:49 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Read this, it will help.
https://ls1tech.com/forums/showthread.php?t=515940
It's not going to be as easy as a 6.0L swap, but you can buy all of the wiring harnesses (adapters) from Speartech. I don't think it will be a problem, but not as easy as a 6.0L swap. I think the above link explains most of it pretty well.
Old Jun 10, 2006 | 07:56 AM
Quik's Avatar
5 year bitches!
buy a lq9 and put 243 heads on it. there you go you got a iron block ls2
Old Jun 10, 2006 | 09:19 AM
SnakeOiler's Avatar
If you buy everything: complete engine, tranny, pcm and wiring harness, all you have to worry about is connecting up stuff such as fuel lines, coolant hoses.
mhorn0817
Jul 8, 2017 01:54 AM
D1SCSS
Jan 25, 2016 10:14 PM
Sales4@Texas-Speed
Aug 3, 2015 03:57 PM
Mark_k
Jul 8, 2015 10:44 PM
Mzay
Jul 6, 2015 11:05 PM
