Grounds in engine harness
Old Jul 16, 2009 | 01:56 PM
thunder550's Avatar
High on diesel fumes
Default Grounds in engine harness
Can someone list all the grounds in the engine harness and on the block? I want to make sure that I didn't miss one when I swapped engine harnesses.
Old Jul 16, 2009 | 02:56 PM
wkdivr's Avatar
There should be 1 at the front on the bottom bolt of the P/S bracket, and one on each side of the heads at the rear. There's also the braided one that goes from the back of the driver's side head to the ground stud on the firewall. I also ran an extra one from that bolt on the P/S bracket to the frame, and one from one of the bellhousing mounting studa to the frame. I also cleaned the ground on my fuel pump hot wire ground, on the frame, and ran a braided ground from there to the body. Everything should be pretty well grounded!
ARC
57
Feb 21, 2022 10:54 AM
creekrat
Aug 2, 2015 01:27 AM
85SS/85GN
Jul 22, 2015 12:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
