Got myself aTORNADO
Old Mar 8, 2006 | 12:40 AM
03lowriderss's Avatar
Default Got myself aTORNADO
yeah hahahaha if thats your opinion on these things well whatever, i added on of these to my 3.0 96 taurus, wasnt lookin for power and it didnt add any but i have had this car since it was new (210,000 miles ago) so i have a pretty good idea of what i get for MPG's and after i installed that thing my gass milage went up , on average about 1-1.5 MPG's. I have proven to myself that it works, plus they sell them at checker auto so if it dont work to improve your mileage keep your receipt and return it , but i am happy with it.
Old Mar 8, 2006 | 02:04 AM
h20junkie's Avatar
The whole idea of the tornado working is laughable. The intake system is set up to give the smoothest airflow possible. The tornado creates rotational turbulence within the intake and reduces the ability of the air to flow into the engine smoothly. Every little bit counts.
Old Mar 8, 2006 | 02:17 AM
TXsilverado's Avatar
actually in theory spinning the air would make the airflow better. try taking a 2 liter coke bottle filled with water, tumping it upside down and letting the water escape. then do it but spin the water into a tornado like fasion and watch how much faster the water escapes the bottle. you'd be suprised.
the only problem i see with the theory is that once you get the air spinning the spin is interupted by having to make that 90* turn in front of the throttle body. after that it has to make its way through the intake manifold which isnt exactly a smoothe path for the air to keep spinning.
Old Mar 8, 2006 | 03:27 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Air will not spin into the intake runners the way it is designed.
Old Mar 8, 2006 | 08:07 AM
A-Dub's Avatar
TXSilverado,
They use the coke bottle example to make you think it works. Air entering an engine and water leaving a coke bottle have nearly nothing in common. Air does not behave like the water does in the coke bottle. The coke bottle is a closed system, so the water going into the bottom bottle has to displace the air that is in it. That air must go to the top bottle. The tornado effect works well in this case because it provides a constant path for the air to travel up through the water rather than the alternative of bubbles and burps if you didn't have the tornado effect. An engine is an air pump. The intake always sees negative pressure. Nothing is being displaced by the movement of the air.
AW
Old Mar 8, 2006 | 08:56 AM
TigerFan187's Avatar
Ive made the comment before-"if you really want SOTP performance from a Tornado you have to port and polish it:! HEHE!
Old Mar 8, 2006 | 11:08 AM
Originally Posted by SilverSierra
TXSilverado,
AW
ive never seen the tornado advertised with a coke bottle. just thinking back ot a highschool science project. the way you put it makes sense. we have had one member on the forums test the tornado on the dyno and come back with positive results...
Old Mar 8, 2006 | 11:12 AM
BlownChevy's Avatar
blownerator
25 Year Member
Bottom Line dont waste your cash.
I love it when these threads pop up.
Old Mar 8, 2006 | 11:29 AM
haha and they always do. we could start a sticky of mods to NOT buy.
Old Mar 8, 2006 | 12:44 PM
PappyDan's Avatar
Tribe Shaman
i vote for the new sticky,TESTED MODS THAT DO NOT WORK (save your money )
