GOT my NX kit today!
Old Nov 12, 2003 | 08:23 PM
Default GOT my NX kit today!
i bought a 20920 NX kit from a guy off this site...im gonna run a 100 shot on the 5.3 and a 150 shot when i swap in the 6.0 ....i was wanderin how much would it cost to have the kit installed cause i dont think i can do it...plus do u guys think i will have a problem shooting a 100 shot on stock pistons and rods? thanks!
Old Nov 12, 2003 | 10:15 PM
ttttt
Old Nov 12, 2003 | 10:48 PM
MonteCarlo31's Avatar
Okie, I am not sure about it but from what I have seen 100 hp doesn't seem to be killing anyone. I'd spray with a window switch and make sure for God sakes that you have a fuel PSI shut off switch w/ a air fuel guage.
Lenny
Edit Forgot to capitalize God, please forgive me
Old Nov 12, 2003 | 11:00 PM
SinCityRT's Avatar
Unless there's specific problems with the 5.3L engine that I wouldn't know about because I drive a different brand, in general V8 engines should be able to handle a 100 shot easily as long as you follow some simple N2O safety rules:
1. Use quality spark plugs, either 1 range or 2 ranges colder than stock. Check your plugs religiously at regular intervals for signs of running lean.
2. ALWAYS use quality gasoline when spraying N2O - try to use 100 Octane (available at many 76 stations) or higher. Higher octane fuel is harder to burn, which gives a more controlled burn. The use of 94 octane fuel and/or octane boosters is better than nothing, but whenever possible you shouldn't skimp on the good stuff.
3. It is recommended to use an ignition source such as the MSD Digital 6+. This system offers dual rev limiters and timing control to pull variable degrees of timing out when using the N2O system.
Detonation is your enemy with N2O - this is probably what causes the most damage in engines under boost. If you can keep it under control you should be just fine.
Old Nov 12, 2003 | 11:28 PM
O3GMC's Avatar
12 Second Club
Hey congrats man, that kit would have been mine if you didn't call it first Parish was spraying 100 shot on his 4.8L 4x4 w/o any problems, so I think the 5.3 can take it. When I get my kit, I'll probably go hardcore on the preventative maintenance, such as a fpss, ngk tr6 plugs, window switch that cuts off the n2o before it shifts (to keep the tranny happy), an a/f guage, and monitor my predator for any knock retard.
I think the motor will be fine, its the tranny I would worry about
Old Nov 12, 2003 | 11:39 PM
so what kinda plugs should i get?
Old Nov 13, 2003 | 09:20 AM
O3GMC's Avatar
12 Second Club
I think people use NGK tr55 or tr6
Old Nov 14, 2003 | 05:42 AM
one03sierra's Avatar
Formerly one92rs
Talking
from what i have read i think they are using the tr6 from ngk. congrats on the system. keep us informed
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 13, 2015 09:59 PM
black03rcsb
13
Aug 13, 2015 04:05 PM
