Got a good update about my problem...
Old Dec 21, 2004 | 07:15 PM
  #21
Sport Side's Avatar
Ok, what are the setups in comparison (new-old) and what were the dyno results of each now that you have both?
Thanks
Old Dec 21, 2004 | 07:29 PM
  #22
XLR8NSS's Avatar
Adkoonerstrator
Before you do a 3.3L put an intercooler on the one you have. I bet Ryan would agree.
Old Dec 21, 2004 | 07:37 PM
  #23
ranwalk's Avatar
Thanks
Original setup was...442hp / 468tq
LQ4 6.0 engine-stock
Gibson shorty headers
2.5 inch dual exhaust into 2 magnaflows dumped
K&N FIPK
43lb/hr injectors
Whipple-10 psi boost
LT1 electric fans
New set up....431hp / 409tq
LQ4 6.0- still stock displacement(Forged pistons,arp head studs,mainstuds,rodbolts, stock rods and stock crank)
Comp cam 224/230 581/592 114lsa
Comp 918 springs and titanium retainers
Thunder racing pushrods
Comp cam lifters
K&N FIPK
43lb/hr injectors
Whipple-6-7 psi boost
Removed electric fans and reinstalled stock fan clutch(plan to put electric fans back on in the near future)
I know alot of the stuff in the new engine doesnt do anything for power but makes it stronger, but I went ahead and listed everything anyway
Looks like the cam has got to be the biggest down fall in the power. Just to big for this setup???
Old Dec 21, 2004 | 09:14 PM
  #24
greentahoe's Avatar
Im definately no expert, but that cam doesnt look like a bad blower cam. I dont understand the loss in power. Did the previous 6.0 have a stock cam? If so than any decent cam with the blower shouldve made more power I would think. That just doesnt make sense to me. I would try a LPE GT2-3 and then a litte nitrous, youre built for it.
Old Dec 21, 2004 | 10:09 PM
  #25
GMC SKI's Avatar
How much timing did he End up with ?
If you can get a Intercooler in the baby like Ryan has It will help tonnes
Run more timing with the intercooler then try to get a new pullie machined
I'm pretty sure you can get smaller ones for it they just don't advertise they have them
Call them up and be forward about it an tell them to sell ya one
Bottom line I bet that every psi of boost with be worth 15-20Hp I bet Depending on how hot things get
Didn't you have an Smc water injection kit ?
Old Dec 21, 2004 | 10:55 PM
  #26
Ryan23silverado's Avatar
I agree
Hey Randy, so did you guys tune it on the dyno at Futral or just run it as it showed up? Do you have a diagnostic program to see what numbers you are flowing on the MAF?
Let the engine loosen up a little before you pound on it too much
Old Dec 22, 2004 | 06:14 AM
  #27
ranwalk's Avatar
I have an SMC alky kit, but didnt use it on either set up. I decided if I could get it tuned without using it I would. I dont trust it enought to HAVE to use it.
He did tune it on the dyno, so I know Allan got everything out of it he could.
Maybe that cam would be better for a centrifugal charger. I'm going to see what Allan suggest then go from there.
Old Dec 22, 2004 | 06:35 AM
  #28
Sport Side's Avatar
I'd swap cams, something close to stock. You're looking to make power inbetween the blowers power band, and possibly the Comp is trying to carry the power band out to far.
Your current camshaft has 48* of overlap @ .006 and doesn't reach a negative till about .050 where it has -1. So, its possible the overlap of the cam isn't helping.
Old Dec 22, 2004 | 07:51 AM
  #29
L-EATER's Avatar
11 Second Truck Club
Is it possible that your stock cam dyno numbers were skewed? We have similar setups and back when I had a stock 6 liter with the stock cam the best I dynoed was 373hp and that was with long tubes. That combo ran 7.99 in the 1/8th mile. Then I added a LS6 cam and TEA stg2 heads and it made 404hp. It ran 7.99 in the 1/8th again !! Now I have a stock 6 liter with the cam in my sig and it has ran a best of 7.91 in the 1/8th.
I think if you get the boost back to 10 psi you will see all the gains you are gonna see with that setup. You will probably hafta have a custom pulley machined, but it will be well worth it.
Old Dec 23, 2004 | 06:30 AM
  #30
ranwalk's Avatar
It's strange. We have similar set ups, but I have made more HP but you have made more torque. I remember when you dynoed the 404hp, you still managed to make 500tq. I'm not extremely unhappy with the hp number even though it is down, but only down 11. The tq number really has me dissapointed. I have been thinking, I'm making approx 4 pounds less boost now. So I am going to see about a custom pulley. If I can get that 4 psi back that should be good for 60-80 hp at the flywheel. I"m also going to see about putting my electric fans back in, that should get me another 10-15 back also.
Next step may be another cam, or maybe geeting rid of the shorty headers and getting some long tubes, that may get my torque back up. This sound like a good plan???
SLOPONY
20
Oct 18, 2016 06:05 AM
mzoomora
Jan 3, 2016 07:06 AM
wrb002
Aug 31, 2015 12:00 PM
DrX
Aug 19, 2015 04:45 PM
AUTOT3K
Aug 16, 2015 06:21 PM
