Got a good update about my problem...
Allan just sent me this message.....
Got the cover off..the cam\crank gear is dot-dot..BUT the crank gear is installed on the wrong "keyway" for dot-dot. Basically advanced by 2 teeth on the crank gear.
Was able to make a new "dot" on the crank gear and got the cam realigned without moving the crank gear. The Rollmaster has multiple keyways on the crank gear and once you move the gear you can't go by the orginal dot on the crank gear..understand?
The cam is now 2 deg advanced..most Comp cams will only have 2 deg ground in,so with a 114 LSA,you should now have an 110 ICL.
Will dyno tomorrow and let you know.
Allan
Allan
Yes, I feel alot better now. I just hope it lays down the numbers it should now. This shows you how good a guy Allan is. He is really backed up with work and I told him not to worry about how long it took to get to it. He went ahead and fit it in to his busy schedule.
Originally Posted by gonzo 6.0
Did you pay good money for a pro engine builder to put this engine together?
That is great news it's an easy fix,man wait until that baby hits the dyno,you'l be one happy SOB
Originally Posted by ranwalk
I did pay good money to get the engine built. I will be talking with him to see if he will help out with the cost of repairs. He may decline and say i should have brought it back to him. If he doesnt pay for part or all of it thats fine. I'm just happy it's ok.
. That setup is going to be awesome once its all set up. Your patience will pay off Im sure!
Doesnt sound like he's going to admit fault,this is one of those things that should not have been brought back to him for diagnostics,did you ask him if he degreed in the cam? IT was a machine shop/pro builder right?makes you wonder what the rest of it's like if he cant out in a cam correctly
Green tahoe would have just beat the **** out of him,then nicely asked for compensation
