Got bored tonight and found this
#21
Originally Posted by parish8
i have used alot of xylene, probably 100gallons or so thru my last truck and i have 10gallons here today for the dyno and track. i mix it at 30% or so and add some lube, i am going to use marval mystery oil from now on i think.
i did kill a couple of stock 02's but they had 50k on them and didn't die for a long time, like 3+months of using the stuff every weekend, the wideband never died.
it works well, i was only able to run 6-7psi on 92 octane and with the xylene mix i was able to run 9psi all day long, i tried an 11psi pully and got a little knock so maybe 10 would have been ok.
i am thinking about ditching the factory 02's all together and running some c12 or whatever that really good gas is, i will still kill the wideband and that thing is expensive but i think i might try it to see how long the sensor lasts, i hear that fuel just kicks ***.
what do you mean you mixed it about 30% I have the same truck as you without the turbo he he ..... how much do you put in the tank ? or do you mix it all and then put it in the truck?
#24
i fill my truck to a little under 1/2 tank on the gauge and then dump in 5 gallons of xylene. that is close to 30% mix.
does is smell any different? I mean like when it burns? like how 106 smells? how much tranny fluid do you put in the 5 gallons?
lukn4trbl355
Oct 21, 2015 11:19 PM
shootermwc
Oct 8, 2015 01:45 PM
