Good or Bad idea??
Old Nov 4, 2009 | 05:22 PM
GSXRider08's Avatar
Exclamation Good or Bad idea??
Ok so i need some advise guys! I have 5.3 right now with bolt ons, built tranny, build rear end with 410 gears. I plan on ordering the radix in like a week and throwing it on the 5.3. I found a 6.0 at the wrecking yard and im going to buy it & build it to suite the radix. I want to stoke it out to the 408, but not sure what is best for the radix? Need some input!!
Old Nov 4, 2009 | 05:58 PM
BOSS302's Avatar
Well, you would need a tvs2300 for the 408, but a 1900 would do you just fine on the 5.3 and 6.0. It's all about how much money you've got and what your end goal is.
Personally, i''d go for the 1900. Build the 6.0 to a forged 370, blow it, and juice it. But that's just me.
ETA: If you are going for the older Radix systems (112, 122), you will need the 122 for anything larger than the 325. The 112 get's maxed out rather quickly on a 6.0 setup.
Old Nov 4, 2009 | 06:29 PM
GSXRider08's Avatar
Ok well im deff going with the 1900 because of the deal im getting on it. So no stroker. What head and cam should i go with if im going to boost it? I just want to get somewhere in the 12's or 11's and ill be happy.
Old Nov 4, 2009 | 06:30 PM
00Silv4.8's Avatar
talk with Thunder550, he had a 408 both blown and turbo'd. Hes the man to go to.
Old Nov 4, 2009 | 06:35 PM
pewterliftedz's Avatar
heads and cam vary depending on your goals, how often driven, and how built ur tranny is lol..
I think you'd be very happy with a low compression 370 and 1900.
ARC
57
Feb 21, 2022 10:54 AM
pittman
Jan 19, 2016 07:06 AM
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
