Going for a set of heads.
Old Mar 6, 2005 | 07:22 PM
gonzo 6.2's Avatar
mine is closer to 9.8 and have never had a detenation issue,Ed wright and Westers and Street and performance have all been involved with mine. My buddys H&C Denali is right at 10.1 and he has had to have his tune backed off due to detenation.Nogo AKA Kevin from east side performance has tuned it alone with one other well known tuner.Thats just been my experience with compression on heavy trucks such as this.
Old Mar 6, 2005 | 09:09 PM
mattrem's Avatar
So what do you think should I keep it down alittle? I think with alot of compression you need to pull some timing.
Old Mar 6, 2005 | 10:54 PM
I'm running TEA 6.0 stage 1.5 heads o-ringed with 77cc chambers.Just tell them what size chamber you need.
Old Mar 7, 2005 | 07:49 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Compression Ratio = (GV+DV+HV-VV+PV) / (GV+DV+HV-VV)
GV (Head Gasket Volume) = Bore(in) X Bore(in) X 12.87 X (Head Gasket Thickness in Inches)
DV (Below Deck Volume) = Bore(in) X Bore(in) X 12.87 X (Inches Below the Deck)
HV (Head Volume) = CC's
VV (Dish, Valve Pocket, Dome Volume) = CC's
(Minus for dish or valve pockets, Plus for dome)
PV (Volume displaced by Piston) = Bore X Bore X Stroke X 12.87
Old Mar 7, 2005 | 04:00 PM
mattrem's Avatar
And that is why Big Tex did it for me!
Old Mar 10, 2005 | 10:50 PM
02sierraz71_5.3's Avatar
mattrem, I would think long and hard on that high compression. My setup is around 10.3-.4 and Im having problems with running some 93 octanes. Had to pull timing on the dyno.
Old Mar 11, 2005 | 08:22 AM
01Blackerado's Avatar
no **** lol, now thats an equation
Old Mar 11, 2005 | 04:02 PM
mattrem's Avatar
How much timing did you pull? What fuel are you using? Mine is 10.2:1 now and I have no problems at all with Allen's tune.
BlackGMC
Aug 17, 2015 07:07 PM
darnie
Aug 10, 2015 10:25 AM
BigEd_72455
Aug 8, 2015 04:49 PM
fullboardmax
Aug 6, 2015 01:35 PM
Sexyrado327
Aug 2, 2015 04:08 PM
