Going for a set of heads.
Old Mar 5, 2005 | 10:43 PM
mattrem's Avatar
Default Going for a set of heads.
Well I have decided to stay N/A. I am getting a set of heads from TEA. Stage 1.5, 2.02 intakes, 1.55 exhaust and 68cc chambers. This will make around 10.8:1 compression. I talked to Brent and he was a huge help, saying that the stock exhaust valve flows better than the rest and will help make torque to get this heavy *** truck rolling.He said my cam will even work great with these heads, so I am stoked. I am thinking a little more cam though. I am going to add a TB converter while I am at it. What do you guys think?
Old Mar 5, 2005 | 11:06 PM
Sport Side's Avatar
Hello,
Could you list the math on 10:8.1 compression?
Thanks bud.
Kyle
Old Mar 5, 2005 | 11:12 PM
mattrem's Avatar
I wish, Big Tex did it for me. I gave him some cc numbers he worked it all out for me. He said too much info, just easy for him to do it for me.
Old Mar 5, 2005 | 11:22 PM
Sport Side's Avatar
Thumbs up
alright cool.
i wasn't even paying attention to what motor you had and how 68cc's will increase your compression w/ your larger SS chambers.
Old Mar 6, 2005 | 09:36 AM
mattrem's Avatar
Yeah, Mine are 71ccs and the compression is around 10.2:1. Big Tex worked the formula showing me about four different cc combonations and 68cc puts me around 10.8:1. I don't want to go ant higher on pump gas.
Old Mar 6, 2005 | 09:44 AM
Why are you going with a TB converter when there are proven highperformance converters out there?I see everything you've done to the truck so far has been first class.Why pinch pennies on a converter with the choice that's available now?
Old Mar 6, 2005 | 09:50 AM
gonzo 6.2's Avatar
What is the lift of your cam?
Old Mar 6, 2005 | 09:59 AM
mattrem's Avatar
whitt1 I went with the TB converter because it is a daily driver and there are two trucks in the 12s with it already on SSS.com, so I think it has proven itself. I don't want to sacrifice the daily driver part with a loose converter. I do see were you are coming from though.
gonzo, The cam is 216/220 and I use 1.8 rockers with it. The lift is 555/563 with my combo. I may make a change though, Brent thinks my cam will work great with the heads.
Old Mar 6, 2005 | 04:04 PM
gonzo 6.2's Avatar
10.1 compression is enough to deal with tuning running premium pump gas.
Old Mar 6, 2005 | 04:09 PM
mattrem's Avatar
Whats is your compression? Who does your tuning?
