Go fast
Old Dec 23, 2015 | 10:35 PM
Flogrown's Avatar
Registered User
Default Go fast
Hello I have an 02 tahoe 5.3 rwd sittin on 20's wrapped with 35's no mods at all truck has a ton of power but I need more out the box speed its like a huge tank any ideas were I could start I want to boost it but dont have the funds at this time....thanks in advance for ideas.
Old Dec 23, 2015 | 10:47 PM
FFDP's Avatar
Remove heavy tires.
Install gears.
Enjoy a faster truck.
Profit.
Old Dec 23, 2015 | 10:57 PM
Flogrown's Avatar
Registered User
Default Offroad alot due to service calls
Big tires are for the ground clearance due to living in the woods I need to know what mods would serve me better as the truck sits
Old Dec 23, 2015 | 11:02 PM
FFDP's Avatar
Install gears, like 4.10's or 4.56's because your big heavy tires already made the factory gearing worse.
Get a custom tune.
Enjoy faster truck.
Profit.
Old Dec 23, 2015 | 11:08 PM
Flogrown's Avatar
Registered User
Will those work with the stock lockers I havent had much experience workin on rear ends hince y I bought a used one to replace the last because of the ring and pinion gear shattering ( playing in mud didnt help)
Old Dec 23, 2015 | 11:19 PM
FFDP's Avatar
I would remove the factory G80 diff, it will just blow up on you someday.
I'd go with a tru-trac diff with a better gear ratio and it'll be a totally different truck. Depending on what you go with, freeway rpm will be higher and might reduce fuel mileage.
Old Dec 24, 2015 | 04:25 AM
11MPG's Avatar
I have a Suburban. My thoughts: Get either 4.56 or 4.88 gear with a Detroit Trutrack. That will wake it up a ton. Speed Engineering sells a set of long tubes and y-pipe. Install those and have an exhaust shop make a cat back exhaust. Spintechs are great for cutting down the drone in these boxy trucks. Go with the 5000 for volume or the 8000 for quiet. Next thing I'd do is get and Airaid MIT tube with a K&N drop in filter. Wrap all of this up with a tune from Black Bear Performance. I'd enjoy that set up for a while and If you want more a cam and springs will be next. If you can find one used a Trailblazer SS intake manifold is a great bolt on.
Headers: http://www.speed-engineering.com/sho...1999-2006.html
Airaid: http://www.airaid.com/search/product.aspx?prod=200-912
Old Dec 24, 2015 | 08:54 PM
GREENSIERRA's Avatar
4.56 or 4.88 gears with a tru trac would make it a completely different vehicle.
my wife drives a Tahoe with 35"s, 4.56s and a tru trac. it defanilty surprises people from a dig
01PewterWS6
Sep 1, 2016 03:11 PM
GRRR65GTO
Dec 6, 2015 06:09 PM
carson84
Dec 4, 2015 06:50 AM
ss4chad
Dec 1, 2015 01:48 PM
