GM Truck Turbo Kit Special Spring Pricing
Old Mar 21, 2005 | 03:22 PM
LivernoisMotorsports's Avatar
LS1TECH, Trucks, Modmotor Sponsor
Default GM Truck Turbo Kit Special Spring Pricing
Spring is almost here so we're running a discount on the Detroit Speedworks 4.8-6.0L Truck Turbo Kit.
Here is a video one of our customers supplied us after installing the kit on his Escalade EXT. The only modification is the turbo kit at 5 lbs. of boost. Everything else down to the exhaust is bone stock.
CLICK HERE
Look at the AWD Torque Steer!
This kit is complete and includes:
  • Polished Garrett Turbo
  • Black Powder Coated Inlet Tubes
  • Black Satin Ceramic Coating on Hot Parts
  • 42 lb Injectors
  • 3 Core Air-to-Air Intercooler
Dual 4 into 1 Tubular Headers w/ 1 5/8" primaries, 1/2" Laser Cut Header Flanges, 2 1/4" Cross Over, 3" Down Pipe, Powder Coated Inlet Tubes, All V-Band Connections, High Quality Silicone hoses w/ Aircraft Grade SS clamps, Tial 38mm Billet Wastegate, and complete detailed instructions.
* Bolt-on Installation; NO SHEETMETAL CUTTING OR WELDING required! Works with factory electronics.
The Battery, A/C, Power Steering, ABS, etc.. remain in the factory locations, so you could put your car back to stock, very easily at any time.
Pricing will be $4,995.00 for the kit. We recommend a shift kit which would add an additional $300 to the cost of the kit.
The turbo is a GT-37 with a custom exhaust housing, however upgrades are available.
We've seen decent gains with the kit on the Escalade at only 5 lbs. Stock it ran 16.8 @ 80 mph and with 24 inch wheels and a lot of heavy stereo equipment it ran 14.2 @ 94 mph.
Below you will find photos of the kit installed on a 2003 Cadillac Escalade
Click here to see the truck in action. Note: This is at 5 lbs. of boost.
Click Here
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
Old Mar 21, 2005 | 03:40 PM
loud5.3's Avatar
CLICK HERE
  • 42 lb Injectors
Click Here
Thank you
Regards,
Rick LeBlanc
Old Mar 21, 2005 | 04:03 PM
Mangled03gmc's Avatar
Baltimore Whore
holy **** thats a good price.Too bad i just blew all my mod mone on a harley.
Old Mar 21, 2005 | 04:31 PM
brave4it's Avatar
Default So which is better?
Which is better to put on a chevy silverado 4.8L? A turbo kit or a supercharger? Which would give you more power and more bang for your buck? Would you have more problems with either one?
Old Mar 21, 2005 | 04:51 PM
We have a customer with an Escalade with an ATI Procharger and his truck runs similar times and mph at the track with 8 lbs. of boost as we do with 5 lbs. The turbo is more efficient (IMO) and makes more power at lower boost levels.
-Rick
Old Mar 21, 2005 | 05:49 PM
Baltimore Whore
both are good but the turbo will be easier on the drivetrain.I am doing a turbo once i get some more loot.
by the way how long will these kits be offered at this price
Old Mar 21, 2005 | 07:27 PM
how much extra would it be to upgrade turbo to a gt42 or gt67?
Old Mar 21, 2005 | 07:35 PM
parish8's Avatar
single digit dreamer
the problem with a turbo, and this is a good problem, is that it makes soo much power you absolutely KILL your driveline. if you plan on keeping it at 5psi you might be ok for awhile but who would keep a turbo at 5psi?
Old Mar 21, 2005 | 07:37 PM
XLR8NSS's Avatar
Adkoonerstrator
I think I could. I'm so lazy I doubt I'd be motivated enought to reach for the ****. I will need a kit to test this theory out on though.
Old Mar 21, 2005 | 07:49 PM
JERRY2500's Avatar
14 Second Truck Club
Believe me you will turn up the **** and get motivated.
