GM hot cam
Old Jun 9, 2008 | 02:05 AM
  #41
2005 Silverado's Avatar
SPAM HUNTER
Originally Posted by thunder550
I wouldn't worry about it Dustin, unless you have money burning a hole in your pocket
Yeah, i just want to be safe, don't want to pull a Chris
Dustin
Old Jun 9, 2008 | 12:15 PM
  #42
kbracing96's Avatar
Dustin
Your risking more by changing the chain then leaving it. You have to pull the oil pump to do it and unless you also pull the oil pan and the pick up tube, then you run a high risk of ******* up the o-ring on the pickup tube when trying to reinstalling the oil pump. I would just leave it. It's pretty low mileage any way.
Old Jun 9, 2008 | 12:26 PM
  #43
thunder550's Avatar
High on diesel fumes
x2....and pulling a "me" doesn't mean skimping out on parts or not being safe. Thanks though. I bought the best parts I could, and have always stayed on the safe side when it comes to tuning.
It's not worth the time or hassle to change your timing chain.
Old Jun 9, 2008 | 01:27 PM
  #44
SPAM HUNTER
Ok, thanks for the input guys! Also, Chris you know i am JFWY.
Dustin
Old Jun 10, 2008 | 07:04 AM
  #45
Tootall's Avatar
Originally Posted by black4.8
that's Jake's truck. I installed that cam, and it later cam back out to have the trans replaced. He sold the cam pretty cheap!
if you'd use the search, you would have found a ton more info on it from him.
Old Jun 11, 2008 | 12:16 AM
  #46
SPAM HUNTER
I did use the search actually, found some info in one thread, but there was no actual numbers, so i thought i would start a thread seeing if there was any new guys running them!
Dustin
Old Jun 11, 2008 | 12:32 AM
  #47
64CAMINO's Avatar
https://ls1tech.com/forums/showthrea...hlight=cam+hot
see post 8
Old Jun 11, 2008 | 12:47 AM
  #48
SPAM HUNTER
Originally Posted by 64CAMINO
Yeah i found that, but again its for an LS1, was hoping for number for a 4.8. But IMO those are some pretty good gains. I still think i am going to be using this cam, but tomorrow is another day, i could change my mind!!
Dustin
Old Jun 11, 2008 | 06:17 AM
  #49
Tootall's Avatar
Dustin
dyno numbers for a 4.8 and the hot cam . . . -not going to happen
you'll change your mind again reguardless
Old Jun 11, 2008 | 11:37 AM
  #50
SPAM HUNTER
Wow, are you the see'r of all? What are next weeks Lotto number?! What do the gas prices jump up to in 2025? Most important of all, When do you mind your own business?
Dustin
