GM hot cam
#41
#42
Your risking more by changing the chain then leaving it. You have to pull the oil pump to do it and unless you also pull the oil pan and the pick up tube, then you run a high risk of ******* up the o-ring on the pickup tube when trying to reinstalling the oil pump. I would just leave it. It's pretty low mileage any way.
#43
It's not worth the time or hassle to change your timing chain.
#45
just found this: http://www.youtube.com/watch?v=6oIXqyteojE
if you'd use the search, you would have found a ton more info on it from him.
#46
#47
#48
Dustin
#49
you'll change your mind again reguardless
#50
Dustin
