Gettin the crank to turn??
Old Apr 27, 2006 | 06:25 PM
dirt track racer 81's Avatar
Default Gettin the crank to turn??
well i started pullin stuff off when i got off work for my cam swap. now i got the front cover off and i was just wondering how im gonna be able to turn the crank shaft around so i can get the dots lined back up? do i need to press the crank back on a bit or what??
Old Apr 27, 2006 | 06:47 PM
thunder550's Avatar
High on diesel fumes
Thread the crank bolt back into the hole in the crank snout (you don't need to put the pulley back on) and put a wrench on it, if you have the spark plugs out and and rockers out it won't take much effort.
Old Apr 27, 2006 | 06:49 PM
FarmerBeau's Avatar
Sexy Party Mod
Old Apr 27, 2006 | 06:59 PM
Alrighty thanks alot..fixin to pull the rockers and pushrods out and then ill pull the plugs out and try that method..
thanks alot.
Old Apr 27, 2006 | 11:31 PM
VortecHOjunkie's Avatar
Yup, thunder knows what he is talkin about, that should solve your problem.
legerwn
56
Nov 15, 2015 10:21 PM
dantheman1540
Nov 1, 2015 02:59 AM
drummer0415
11
Oct 24, 2015 08:16 PM
FormulaZR
Sep 14, 2015 05:23 PM
Justin87gn
Sep 10, 2015 12:06 PM
