Gen 4 5.3 vs 4.8
Old Dec 26, 2012 | 11:20 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default Gen 4 5.3 vs 4.8
Looking to take the ol 5.3 as far as I can before I do an ls7 swap. So I have a few questions Id like to confirm first. I know in gen 3 motors the 5.3 had a dished piston and the 4.8 had flat tops, is this still the case in the gen 4?
Old Dec 26, 2012 | 11:34 AM
1994Vmax's Avatar
No. Your Gen IV 5.3 has flat top pistons in it and is 9.9:1 compression with either the 243/799 64 cc heads it has on it. GM did this in the Gen 3's of course with the L33. The 4.8 actually has the exact same top end as your 5.3 which coupled to it's shorter stroke nets only 8.8:1 compression( GM powertrain lists all these specs).
The LR4 and LM7 used to share the same heads as well but with the 61 cc chambers the difference from having dished pistons in the 5.3 and flat tops in the 4.8 kept their static compression ratio about the same.
That is no longer the case with the Gen IV's.
Old Dec 26, 2012 | 11:56 PM
Piss Pumps for Sale
Thanks thats exactly what I was looking for.
Anyone know how much I need to mill my stock 243's to get my compression ratio up around 11:1? Im thinking somewhere around .035? I know I shouldnt have any pvc issues with this setup or problems getting my intake to seal to the heads, also Ill obviously be getting a D.O.D. delete aswell as the vvt.
I also recently bought a 3200 stall for the 6L80e, plan on going with a tr224 224 112 lsa cam, but I am open to suggestions
Old Dec 27, 2012 | 10:51 PM
Piss Pumps for Sale
bueller? bueller? bueller?
Old Dec 29, 2012 | 11:42 PM
Piss Pumps for Sale
come on guys I know someone would have a general idea?
Old Dec 30, 2012 | 10:52 AM
2007chevy5.3l's Avatar
I would talk to one of the guys that knows cams before you go milling and upping the comp before you know what cam you want. Static compression isnt as important as Dynamic compression and you need to know what that is using a calculator and intake valve events with a certain cam/head combo
Old Jan 2, 2013 | 05:16 PM
craigsix's Avatar
i woulnt mill more than .030 with a big cam so you dont have valves touching pistons! or have the pistons notched for more clearance.
Jblake
Aug 17, 2015 12:59 PM
Denali08
Aug 9, 2015 04:34 PM
JordanH
Aug 8, 2015 07:59 PM
vmaxpro
Jul 27, 2015 10:45 PM
06 4.8
Jul 15, 2015 07:17 PM
