Gen 3 to Gen 4 Swap
Old Mar 18, 2013 | 05:27 PM
2K Silvy's Avatar
Default Gen 3 to Gen 4 Swap
Okay guys and gals I need some help on what is needed to do a swap on these engines. My truck is a 2000 Silverado 4.8.
The only reason I ask is because I can pick up a 2007 Gen 4 5.3 with 243/799 heads and only 70k miles for $500 bucks. Great deal if you ask me. Just wanting to know besides DOD/AFM what would need to be changed over?
I planned on either boring the 4.8 and taking it to a 5.7 with the corresponding rods/crank. However this is just a really really good deal. I have seen the heads cost more than 500 bucks.
The guy gave me some numbers off the block and heads (I think the head number might be wrong) 12576178 for the block. That lead back to the LY5, is that right? The head numbers were 6289L2340777. No idea on that one, looks wrong to me.
He now added it was out of a 2007 Classic and not the nnbs.
Last edited by 2K Silvy; Mar 18, 2013 at 05:55 PM. Reason: Added some super cool numbers.
Old Mar 18, 2013 | 06:36 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The number he gave you on the head was etched into the out side and wont give you any info. Ask him for the 3 or 4 digit code cast into the top corner next to the valve cover.
Old Mar 18, 2013 | 06:56 PM
2K Silvy's Avatar
He says it is the 243 heads. Does that help at all?
Old Mar 18, 2013 | 07:04 PM
1FastBrick's Avatar
Yes then they are the 243 castings and they did come on the later 5.3L as well as the LS2's
Old Mar 18, 2013 | 07:14 PM
2K Silvy's Avatar
So it should be good to go? No AFM/VVT?
Old Mar 18, 2013 | 08:46 PM
mdwatts11's Avatar
Sounds like an LY5. They have afm but no vvt. You can do the dod delete pretty easily, but you'll need the harness and computers from that truck as yours will not work.
Old Mar 18, 2013 | 09:37 PM
dmelvin's Avatar
Or change the Reluctor wheel to a 24x.
Old Mar 18, 2013 | 09:42 PM
2K Silvy's Avatar
Why won't it? From what I've been reading I was under the impression that the differences were the crankshaft position sensor, and the knock sensors. I thought a simple extendo of the harness would make it work. After the DOD delete anyways. What am I missing?
Old Mar 18, 2013 | 09:44 PM
2K Silvy's Avatar
Originally Posted by dmelvin
Or change the Reluctor ring to a 24x.
Figures I would respond while someone else haha. So if I go ahead and do that would that be all that needed to be changed? I planned on opening it up and checking everything out. Replacing anything that looks wore.
Old Mar 18, 2013 | 09:59 PM
dmelvin's Avatar
I believe the cam sensor is also in a different spot.
Should be, there is a few threads floating around on guys that have done the swap before. Try to find them with the search.
