Gauge install progress/pics
#35
need some help:
I need a 12v source that comes on when the ignition is in the "ON" position, but does not turn off when the truck is started and was wondering what that source typically is. I have all the wiring/connector diagrams for my truck, so I really just need the typical source or sources so that I don't cause any problems, also, any upgrades that might be needed like a slightly larger fuse or whatever.
#37
Here are the pics of where and how I mounted the remote senders for the fuel pressure and boost gauges. I used rubber to surround the gauge to insulate them from causing vibration noises and used zip-ties to secure them. The line with the purple tape is the fuel pressure line, the other is the boost.
The braided lines run out of the stock openings on the back of the fuse box cover. I used permatex high temp pipe sealant on all the NPT threads. enjoy!
#39
Originally Posted by moregrip
Here are the pics of where and how I mounted the remote senders for the fuel pressure and boost gauges. I used rubber to surround the gauge to insulate from causing vibration noieses and used zip-ties to secure them. The line with the purple tape is the fuel pressure line, the other is the boost.
#40
Originally Posted by Flipper
You're doing a helluva job there Grippy!
great picture of the radix!
