gaskets
Old Aug 19, 2006 | 07:51 AM
Default gaskets
intake manifold? water pump to block? do I have to replace em, from the 4.8 to 6.0 swap?
Old Aug 19, 2006 | 08:07 AM
thunder550's Avatar
High on diesel fumes
I say no...I reused all mine. Just take a look and make sure they are in good shape.
Old Aug 19, 2006 | 09:13 AM
BigRed53's Avatar
but also remember, its sometimes a good rule of thumb to replace gaskets while your there. i always replace my gaskets when doing a mod on a truck or just a fix, gives me the warm and fuzzy feeling. and relatively inexpensive.
jared
Old Aug 19, 2006 | 09:15 AM
well the intake gasket is like 95$ so thats why I ask... should I just put a bead of silicon (reg.) on it then seal.
Old Aug 19, 2006 | 01:37 PM
budhayes3's Avatar
PT's Slowest Truck
If the intake manifold gasket looks OK, I'd put it back on dry...just in case you have to remove it again, you won't have to scrape all of that silicone.
I don't like re-using gaskets myself, but for $95 bucks, I might try re-using my intake gaskets when the time comes, especially since pulling the manifold is no big heartache. The cheaper, harder to replace gaskets I'd do personally for some cheap insurance (water pump, timing cover, etc.) You'll probably be fine re-using them (seems like guys do it all the time), but I'm just giving my .02.
Old Aug 19, 2006 | 02:52 PM
Quik's Avatar
5 year bitches!
gaskets are ment to be reused!!!! unless you have a 98 fbody or vette water pump and they arent meant to be
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
lxcoupe
Oct 4, 2015 08:07 PM
1989k1500
Sep 29, 2015 10:53 AM
sTNT971
Sep 26, 2015 04:22 PM
