what causes plug fouling?
Old Aug 19, 2006 | 11:28 AM
Default what causes plug fouling?
right now i have counted probably 3 or 4 of my plugs that i recently removed have black on the whire ceramic surrounding the spark tip. granted i have oil consumption issue pretty bad from some bad valve seals (i assume, will see with new heads) but what causes plug fouling or the black on the ceramic tips?
Old Aug 19, 2006 | 11:38 AM
shandy294's Avatar
the oil will do it
Old Aug 19, 2006 | 11:55 AM
alright so once i replace the heads and get the valve seals in check this shouldnt happen anymore? thanks for the info
Old Aug 19, 2006 | 12:10 PM
shandy294's Avatar
I'd think so...the leaking past the guide seals has to pretty good to cause accumulation at the electrodes. Good luck with the new heads.
Old Aug 19, 2006 | 01:55 PM
Quik's Avatar
5 year bitches!
fouled plugs could be cause of a poor tune
also the oil can also be sucked thru the intake like most Gen IIIs do. ive seen where ppl change hte heads and still hav that issue
Old Aug 19, 2006 | 02:03 PM
budhayes3's Avatar
PT's Slowest Truck
Could be the oil or it may be running rich
Old Aug 19, 2006 | 03:16 PM
i doubt it was running....when it was tuned before the LT's it was between 13.1 and 13.6....pretty lean and after the LT's i never went WOT so i dont think it would have a chance to run that rich. its not just normal oil consumption....it put a oil cloud out the back after the truck has been resting for a while and only upon ignition, not while running at any amount of throttle or at idle.
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
