Gasket match question
Old Aug 8, 2007 | 08:03 AM
white1's Avatar
Default Gasket match question
Need some advice. While I got my engine down, and needing to get one head cleaned up anyway, Im going to go ahead and get tehm shaved .025, and a 3 angle valve job. Im thinking while I have everything down I may unshroud the valves, and gasket match the exhaust ports too. I noticed the exhaust ports arent round like hte gaskets, would I be doing more harm than good, or am I wasting my time?
Old Aug 8, 2007 | 09:47 AM
Tootall's Avatar
I think that you're wasting your money on a port job for the little cam that you have planned. Now if you were going to run the larger cam that would be different.
Old Aug 8, 2007 | 10:55 AM
Grumpy5.3's Avatar
I wouldnt do alot to the exhaust port either. You mentioned gasket matching them, but you would hurt more than do good. A CNCd head exhaust port isnt gasket matched???!!!???
Old Aug 8, 2007 | 11:32 AM
white1's Avatar
K thanks. BTW as far as the cam. Im thinking if I know me as well as some of the guys here, Ill wind up getting another decently sized one in the future
Old Aug 9, 2007 | 11:03 PM
Stoichiometric's Avatar
I would not bother to match the ports to the gaskets. The D shape should help minimize reversion of exhaust, there is more to be gained in other areas. If the search works on Tech, look for do it yourself head clean-up threads.
thunder550
Oct 8, 2015 04:53 PM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Ketis
Jul 23, 2015 12:37 PM
jmarkway
Jul 18, 2015 09:23 PM
