Gas pedal is hard to push...
Old Oct 17, 2003 | 03:17 PM
Coop's Avatar
Default Gas pedal is hard to push...
OK, I have a '99 2-door tahoe, 5.7L. 67k miles on it. My gas pedal is weird, when you go to push it, it takes a little bit of force to get it started and then it lets go. Tried spraying wd-40 on the pedal, pedal linkage, cable, and the spring/joint at the TB. Nothing seems to help. Does anybody have any ideas? It is really annoying because if I am trying to baby my truck it looks like I can't drive because I am always jerking because when the pedal lets go from whatever is making it hard it is real easy to push after that so I like halfway floor it!
any help will be GREATLY appreciated!
Old Oct 17, 2003 | 03:45 PM
JSmith's Avatar
Default Re: Gas pedal is hard to push...
Try taking off your intake tube and cleaning the inside of your TB and butterfly. Buildup causes the blade to stick. It happens on the LS1 based truck engines quite a bit.
Old Oct 17, 2003 | 04:37 PM
he is right on the money
common problem
clean the throttle blade and body
real well - use STP or Gumout
throttle body cleaner....
works every time....
SloSVO
Nov 22, 2020 07:34 PM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
sTNT971
Sep 26, 2015 04:22 PM
GM1697
Sep 9, 2015 10:31 PM
