Gas Gauge Messing Up?
Old Mar 6, 2004 | 10:14 AM
Default Gas Gauge Messing Up?
My Gas Gauge Has Gone A-wall. I'll Fill My Tank Up And It Will Randomly Go From Full To Empty And Continue This Pattern Until I Start Moving, But If I Stop And I Am Just Ideling It Starts It Again. What Could Be Causing This And What Can I Do About It?
Old Mar 6, 2004 | 10:40 AM
BlownChevy's Avatar
blownerator
25 Year Member
Sounds like the sender in the tank.....Still under Warr?
Old Mar 6, 2004 | 12:00 PM
Nope, is it hard to replace.
Old Mar 6, 2004 | 12:41 PM
BlownChevy's Avatar
blownerator
25 Year Member
Best thing to do would be hook it up to scanner and see what the actuall value of the tank level is. IF it is the sender, you will need to drop the tank and replace the part.....PITA
Old Mar 6, 2004 | 05:22 PM
ThunderZ28's Avatar
12 Second Club
welcome to the club
Old Mar 6, 2004 | 10:26 PM
agreif's Avatar
Same thing happened to mine. Sender unit...basically a dead spot in the resistor. Had it done under warranty but asked what it would normally cost, dealer quoted me $400.
Andrew
Old Mar 6, 2004 | 10:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
DAMN 400.00!
BADaSS69:
If you find that is the problem, e-mail me I will see how much a new sender is for ya. Anything I can do to help.
Old Mar 6, 2004 | 10:59 PM
ThunderZ28's Avatar
12 Second Club
would like to know also. sucks not knowing how much gas you have used cause you have been romping on it a little
Old Mar 7, 2004 | 03:13 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by 01 Thunder
welcome to the club
Yes yes! I'm a member too
Old Mar 7, 2004 | 07:48 AM
threezees's Avatar
Sender module is way over 400 bucks and thats no labor.These modules are a common failure.
