Are full length Headers worth the hassel?
Old Apr 29, 2008 | 05:34 PM
UBLUZIN03's Avatar
If you have any mechanical experiance headers are no hassel...the hardes part for me was the ORY...
Old Apr 29, 2008 | 06:33 PM
Truckshop's Avatar
if you go with pacesetters you will not need o2 extensions. just a tune and it WILL be worth it!!
Old Apr 29, 2008 | 08:34 PM
quicksilverado's Avatar
Originally Posted by MPFD
I've got a cam, I've never seen a set of header that didn't have exhaust leaks eventually. The hassel is buying O2 exenders new true dual exhaust, etc seems like a lota money for a 6-10 hp gain.
Use the stock MLS gaskets and they will not leak. Most LT headers have o2bungs in them so there is no need for o2 extension wires. You can have flanges welded to the stock y-pipe and you can use an aftermarket catback. With a tune you should see 25-30 rwhp and about the same for torque. Whether or not its worth the money, only you can answer that question.
Old Apr 29, 2008 | 08:47 PM
barley's Avatar
they're a supporting mod your going to need em sooner or later if you want a fast truck. I dropped .2 sec off my et with mine
Old Apr 29, 2008 | 08:58 PM
outlawz2004's Avatar
At first I didn't think they really did much, and then I got my tune adjusted and they came alive. I am glad I got them. I didn't need extensions. I used the gaskets that came with the headers and so far no leaks thankfully. They have been on there a little while now. I didn't know most people didn't use the supplied gaskets, so I don't know how long they will last. If I was you I would either reuse the stock ones or get some good copper ones. With the longtubes, no cats, adjusted tune, a cutout, and shorter tires I dropped 1.2 seconds off my quarter mile time. I know this isn't the normal, but it did it.
Old Apr 29, 2008 | 09:08 PM
go with the pacesetters they are awesome and look great. get the stock gaskets from gm though.
Old May 1, 2008 | 04:09 AM
viciousknid's Avatar
Where's the Beef?
Everything they said.
Stock gaskets work real well. I seen a real nice gain with mine. As stated, it's an easy install, the hard part is the ORY.
Old May 1, 2008 | 04:29 AM
LowBlack99's Avatar
The ORY can be pain, mine was a 2 piece and a friend of mines was a 3 piece? his was much more difficult. You can re-use your stock gaskets as well. I have one small leak in the ORY at the clamp I just ain't got around to tightening yet other than that no problem. Gained .2 without a tune.
chvy=power
Sep 8, 2015 11:05 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
zblee
Aug 3, 2015 03:45 AM
sauldgold
Jul 23, 2015 02:15 PM
Ketis
Jul 23, 2015 12:37 PM
