fuel test port location for nitrous?
Old Nov 20, 2004 | 02:39 PM
OrlandoFL4.8's Avatar
Default fuel test port location for nitrous?
Im installing a nx wet kit on 2001 4.8 silverado. It says that I should tap into the fuel test port for the fuel supply. I found a tube comming off of the fule rail on the left side of the engine (pasenger side) with a cap on it so I unscrewed the cap and plugged into it with the fuel line that goes into the nitrous kits fuel sylonoid and it threaded just fine. I started the truck and opened only the fuel sylonoid and nothing came out of the nozzle except a little puff of air? Shouldnt fuel be comming out, and is this the correct place to tap in? Sorry if this sounds stupid but this is my first install.
Old Nov 20, 2004 | 02:53 PM
RedVHO's Avatar
There is a valve stem pin inside of the port. Unplug your fuel pump fuse and crank over your engine. That will get any pressure out of the fuel lines. Then remove the pin that is in the port, and reattach your fuel line. Then you can put in the fuel pump fuse back in.
Old Nov 20, 2004 | 03:35 PM
Thanks I see what your talking about and I can see the pin inside the valve...do I just pull it straigh out with a pair of needle nose plyers or is there a certain way? i dont want to damage it incase I have to put it back
Old Nov 20, 2004 | 03:51 PM
busta9876's Avatar
it's exactly like a valve stem in a tire, it will unscrew. go to parts store and ask for a valve stem remover. a few bucks, if you have a pair of needle nose small enough, just put them in and try to unscrew it. but best to get the right tool.
Old Nov 20, 2004 | 10:10 PM
RedVHO's Avatar
You can even get 'em at Walmart. I don't think you should attempt the needle nose.
Old Nov 20, 2004 | 11:07 PM
Deckhand's Avatar
its called a schrader valve. its like a little screw driver with a split end (kinda like a split fork), and you stick it in there, and unscrew.
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
