fuel rich
Old Oct 13, 2009 | 08:20 PM
bad intentions's Avatar
Default fuel rich
ok guys i have an 09 1500 and i got a couple of codes after i did a simple filter switch.
i got p0175 and 172 when we checked the codes it said it was running rich. now my truck has only 4,000 miles on it i dont think its the o2s but we never know.
second all the intake and spacer are put on correctly checked twice.
the only thing is that i was -12 and -16 on both trims at idle.
the codes after the re tune have gone away dont know if i should still clean the maf or wait for the codes to come back then clean it. any advice would help.
Old Oct 13, 2009 | 08:32 PM
BlackGMC's Avatar
Resident Retard
Did you descreen the MAF?
Old Oct 13, 2009 | 08:41 PM
my truck is an 09 it comes with out a screen kinda looks like a diesel maf
Old Oct 13, 2009 | 08:44 PM
BlackGMC's Avatar
Resident Retard
did you disconnect any of the intake tubing when you switched out the filter?
Old Oct 13, 2009 | 08:50 PM
yes i did but i checked everything and it all looks good.
Old Oct 13, 2009 | 08:51 PM
Wheatley's Avatar
Truck Sponsor
When it was tuned,was the MAf table scaled?
Old Oct 13, 2009 | 08:58 PM
i would think so
it was tuned a while back with my 1st filter the volant power core, which i thought was to restricted then i swapped it out for a k&n brand new at the box no excessive oil and about an hour later it the codes went on.
Old Oct 13, 2009 | 09:02 PM
after i got it checked the codes went away then i had it checked by my tuner and re tuned to high octane since there was a misunderstanding the 1st time and truck felt better plus the drive was at least 10 miles and no code appeared.
Old Oct 13, 2009 | 09:08 PM
i think what i might do is pick up a mas air flow cleaner clean the sensor and hope the codes stay away for good cause i really like the new filter that i am using now.
Old Oct 15, 2009 | 10:23 PM
ok codes have been gone for two days. i just got done cleaning the maf. and when i went to recheck with my tuner found out we were running 87 octane instead of 93 wow what a change in performance.
bk_cauley
40
Aug 17, 2018 05:45 PM
1bdbrd
Aug 23, 2015 03:24 PM
02singleturbo
19
Aug 20, 2015 05:55 PM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
