Fuel Rail Problem
Old Oct 4, 2005 | 01:49 AM
99Silver6.0's Avatar
Originally Posted by 4.8LGMC
so there's no difference in the balance of a 4.8 and 6.0
No. These engines are internally balanced. No weights on the flywheel.
Old Oct 4, 2005 | 01:51 AM
4.8LGMC's Avatar
ah......so why won't the 4L60E hold up behind the 6.0?
Old Oct 4, 2005 | 01:58 AM
4.8LGMC's Avatar
another thing.......do you have to get the ecu reprogramed for the 6.0
Old Oct 4, 2005 | 05:19 AM
tdrumm's Avatar
In response to your questions above
1.) Because it isn't strong enough
2.) Yes you can have your 4.8 PCM reprogrammed for the 6.0
Good luck!
Old Oct 4, 2005 | 08:46 PM
60E is weak. The motor will run fine on the 4.8 PCM but highly recommend a good tune ONCE you get a tranny that can hold the power input.
Old Oct 4, 2005 | 11:30 PM
4.8LGMC's Avatar
So reprogram the ECU for the 6.0 and get a 80E......i have someone who has a 80E with a 3k stall......i might swap him my 4.8 and 60E for it
The_W
Aug 15, 2015 08:07 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
