Fuel Rail Problem
Old Oct 3, 2005 | 11:52 PM
4.8LGMC's Avatar
Default Fuel Rail Problem
I bought a 2002 6.0 long block.......i bought a 6.0 intake off of ebay......found some interesting things about the 6.0 fuel rails and the 4.8 fuel rails.....the 6.0 intake i got has only one fuel port for the fuel line......the other one goes to the front on the top side of the intake........on my 4.8....both the supply and return are on the LH fuel rail........can you swap the fuel rails and it run?
Old Oct 3, 2005 | 11:56 PM
99Silver6.0's Avatar
Some of the other rails are not return style rails. You can re-use your current rails and such.
Old Oct 4, 2005 | 12:03 AM
4.8LGMC's Avatar
good.....i was kinda worried......i have another question......can u use the 4L60E tranny on a 6.0?
Old Oct 4, 2005 | 12:22 AM
Yep. It wont last, but yes it bolts up.
Old Oct 4, 2005 | 12:54 AM
GoldenVelvet's Avatar
The 6.0 is virtually identical to the 4.8. Most everything will swap right over.
Old Oct 4, 2005 | 01:28 AM
4.8LGMC's Avatar
what about the flywheel......can u use the flywheel from the 4.8 on the 6.0
Old Oct 4, 2005 | 01:30 AM
Youll wanna swap flywheels.
4.8LGMC's Avatar
so get a 6.0 flywheel
Old Oct 4, 2005 | 01:40 AM
No. Use your 4.8 flywheel.
Old Oct 4, 2005 | 01:43 AM
4.8LGMC's Avatar
so there's no difference in the balance of a 4.8 and 6.0
