Fuel Rail Problem
EFI | GEN I/GEN II/GEN III/GEN IV Engines |Small Block | Big Block |
Fuel Rail Problem
Oct 4, 2005 | 01:49 AM
11
99Silver6.0
May 2002
Olathe, Kansas
Quote:
Originally Posted by
4.8LGMC
so there's no difference in the balance of a 4.8 and 6.0
No. These engines are internally balanced. No weights on the flywheel.
99Silver6.0
Find More Posts by 99Silver6.0
Oct 4, 2005 | 01:51 AM
4.8LGMC
Sep 2003
Gainesville, Tx
ah......so why won't the 4L60E hold up behind the 6.0?
4.8LGMC
Find More Posts by 4.8LGMC
Oct 4, 2005 | 01:58 AM
13
4.8LGMC
Sep 2003
Gainesville, Tx
another thing.......do you have to get the ecu reprogramed for the 6.0
4.8LGMC
Oct 4, 2005 | 05:19 AM
14
tdrumm
Oct 2003
Northeast, NJ
In response to your questions above
1.) Because it isn't strong enough
2.) Yes you can have your 4.8 PCM reprogrammed for the 6.0
Good luck!
tdrumm
Find More Posts by tdrumm
Oct 4, 2005 | 08:46 PM
99Silver6.0
May 2002
Olathe, Kansas
60E is weak. The motor will run fine on the 4.8 PCM but highly recommend a good tune ONCE you get a tranny that can hold the power input.
99Silver6.0
Oct 4, 2005 | 11:30 PM
16
4.8LGMC
Sep 2003
Gainesville, Tx
So reprogram the ECU for the 6.0 and get a 80E......i have someone who has a 80E with a 3k stall......i might swap him my 4.8 and 60E for it
4.8LGMC
Is my fuel setup correct
The_W
08:07 AM
How to mount regulator on fuel rail (Holley Hi-ram)
TAPyvehc93
06:35 PM
Returnless system, Walbro 450, ID1000, E85... anything wrong here?
lxcoupe
02:12 AM
Need help - Stumble at first cold start, dealer can't find anything wrong
Mossyoakglock
08:30 AM
Tags
60
fuel
problems
rail
Back to Subforum
View Next Unread
a small question about 02 sensor simulators
07:07 PM
