FUEL Pump wires in main fuse box???
Old Nov 7, 2008 | 12:46 PM
nonnieselman's Avatar
The inline is coming out of this bitch hahaha
John
Dont run the pump dry.. they usually die there after.
How much you want for the inline???
Old Nov 7, 2008 | 12:47 PM
Mangled03gmc's Avatar
Baltimore Whore
What Im not gona do that, I don't know, might hang on to it.. I will let you know thow..
John
Old Nov 7, 2008 | 12:55 PM
dewmanshu's Avatar
Moderately Differentiated
YAh Yah yah, after further inspection, I am going to run a relay, I didn't think or realize there was a oprah size space under the fuse box, you bastads.. Again I want my **** to look neat under there damnit. HAHAHAH This is the way just to be sure This isn't exactly how I will do it, but you get the point.. Thanks you guys are so $%^&
Bingo. I'll admit I don't like to ground to the frame that far back unless you already have a ground jumper from battery to frame in that area. Otherwise I'd run the ground the whole way or from a location where ground can't be compromised. Just me.
Old Nov 7, 2008 | 01:02 PM
Sounds good...
Old Nov 7, 2008 | 01:31 PM
sharpshooter's Avatar
did you get any fittings for the top of that pump and the sock?
Old Nov 7, 2008 | 02:12 PM
Baltimore Whore
I did for the top of the pump, nothing on the sock, I need to actually see it for my self
John
Old Nov 7, 2008 | 02:23 PM
jay racing sells the sock, without it you won't have a pre-filter
Old Nov 7, 2008 | 02:26 PM
dewmanshu's Avatar
Yeah, don't run that pump without a sock. Crazy **** sits in your tank.
Old Nov 7, 2008 | 02:37 PM
Baltimore Whore
Na I got that sock with the pump
John
Old Nov 7, 2008 | 10:52 PM
OrlandoFL4.8's Avatar
I used the 8mm stud on the fuse box for my main power to the relay, cant realy remember a whole lot without actually going out there to look, but here is wiring diagram I did of how I wired mine up..works great!
5.3Okasai
Mar 9, 2022 01:07 PM
wrb002
Aug 31, 2015 12:00 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
