Fuel pump upgrade kit
Old Dec 3, 2012 | 09:00 AM
ihdude's Avatar
Default Fuel pump upgrade kit
Does anyone make a fuel pump kit either inline or in-tank? Looking for something with minimal modifications. Any recommendations on inline vs in-tank?
Old Dec 3, 2012 | 09:21 AM
shorty's garage's Avatar
Email racetronix they can set you up
Old Dec 3, 2012 | 09:27 AM
TX Tahoe Z71's Avatar
Check out a voltage booster, like Magnavolt or Kenne Bell Boost-a-Pump. My stock flex fuel pump is keeping up with my 75# injectors just fine with a KB BAP.
Old Dec 3, 2012 | 10:12 AM
ihdude's Avatar
I found a racetronix in tank upgrade kit that said was a universal kit and no application specific. How difficult is it to modify this kit to work?
Also on the boost-a-pump. They seemed to be set up for boosted applications only. Will this work with N/A or nitrous?
Old Dec 3, 2012 | 11:03 AM
Yes, the Magnavolt has an RPM switch (comes on at a set RPM), and the KB has a hobbs switch (boost referenced, or vacuum referenced for NA), but if you solder the wires together, it will always by providing 17.5 volts (IIRC) instead of 12V. Check their website though, I don't want to steer you wrong, but I know they are used in NA setups too.
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
thunder550
Oct 8, 2015 04:53 PM
Ammadien
Jul 22, 2015 08:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
