fuel pump setup? an fittings, etc?
Old Mar 17, 2008 | 07:58 PM
Klive's Avatar
Banned
Default fuel pump setup? an fittings, etc?
i know i saw a thread one time where someone had taken one or two 255lph pumps (i already have 1) and installed it into the stock unit and converted it into AN fittings for the supply and return lines. i want something that is directly wired, plug and play. does anyone build a setup like this or know where i could send my pump (and another one) and my stock sending unit to have it converted? anyone???
Old Mar 17, 2008 | 08:02 PM
Derek @ EDO's Avatar
FormerVendor
Well, I wouldnt run both at one time, it will cause premature pump failure from the heat.
A hobbs switch setup would work great!
Its easy to do, ill get you some instructions.
Old Mar 17, 2008 | 08:11 PM
Klive's Avatar
Banned
awesome!! you rock... the hobbs setup is usually for boost isn't it? I'm thinking maybe do one on a switch for fueling the nitrous... (unless I do end up with FI between now and then.)
Old Mar 17, 2008 | 08:12 PM
FormerVendor
Yea, that would work with a switch for an NX system!
Old Mar 17, 2008 | 08:35 PM
FormerVendor
Send trtturbo a PM and ask him what fittings you will need.
I thought he had it laid out at one point but i guess not!
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
