Limitations of stock fuel lines
High on diesel fumes
Anyone know what the limits are of the stock fuel lines on a return system? I'm going to be running billet fuel rails with an aftermarket FPR, 96#/hr injectors, twin in-tank pumps. Should I be looking at replacing all the stock fuel lines too, or will those be ok with all the other stuff?
i think parish ran stock lines but had a few minor hiccups. for the cost of fuel lines i would run them. its not worht the hassle or money of pulling and rebuilding a motor for the cost of fuel lines
even then you werent pushing the limits of things, wasnt you low numbers for most part? something else is going on. didnt you have a oil issue before?
What low numbers are you talking about? And what oil issue? I have some oil smoke out the tailpipe intermittently, but I'm about 99% sure it's from the turbo, not the engine.
Mmmkay I'll look into running new lines. What would you suggest for size of feed and return lines?
i was saying you never did crank it up over 6xx to wheels. i think at the numbers you were at you within all reason of your combo
you wont know for sure till you tear it down and see what happend
Using a couple of different online calculators they seem to be right around 700 at the crank, give or take about 20.
Of course, I'm shooting for 10's so a 10.99 @ 125 in a 5400 lb race weight gives me roughly 800 at the crank.
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
