Fuel Pump Harness Getting Hot - is there a fix????
Old Jul 9, 2007 | 08:31 AM
agreif's Avatar
Default Fuel Pump Harness Getting Hot - is there a fix????
Guys, 2000 4.3L engine with the fuel pump going on the fritz. It sounds similar to this problem https://www.performancetrucks.net/fo...+won%27t+start. The fuel pump was replaced and worked for about 10 starts and then won't even prime when the key goes to "ON". Found this harness (attached) was getting hot and the 2nd prong had a burnt spot on it. Of course this wire traces back to the hot wire on the fuel pump. For the short term the connector was cleaned up and plugged back in and that worked, but that wire is still getting hot/warm?? This is the harness that the plug on the pump plugs into. Why would this wire be getting hot? Any idea?
Thanks guys.
Attached Thumbnails Fuel Pump Harness Getting Hot - is there a fix????-harness-002.jpg   Fuel Pump Harness Getting Hot - is there a fix????-harness-003.jpg   Fuel Pump Harness Getting Hot - is there a fix????-harness-005.jpg
Old Jul 10, 2007 | 06:40 AM
agreif's Avatar
no one?
Old Jul 10, 2007 | 09:38 AM
Bish's Avatar
I'd guess the pump is no good or your fuel filter is clogged. Pump working harder will cause it to draw more current (making wire hot). I know a common failure is the wiring on the pump but I have not heard the harness getting hot.
I think you would blow a fuse if you had the wrong harness.
Old Jul 10, 2007 | 11:01 AM
2006 8.1's Avatar
Check, or just replace the fuel filter. Always check the fuel filter first in a fuel related issue. It is the cheapest fix. It may not be the issue, but I would start there first.
Old Jul 13, 2007 | 04:10 PM
BIGJT's Avatar
Registered User
Fromm 99 To 02 Gm Had A Problem With The Wireing Horness The Claim When Your Pump Burns Out U Should Ckeck The Wires At The Plug The Start To Melt Together And All U Have To Do Is To Replace The Plug.
Old Jul 14, 2007 | 03:27 PM
04 ss man's Avatar
Most new ac delco pumps that u get from autoparts stores r coming with a replacement harness to wire in.
5.3Okasai
Mar 9, 2022 01:07 PM
wrb002
Aug 31, 2015 12:00 PM
MS3Z
Jul 30, 2015 06:17 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
