Fuel pressure sensor with stock rails?
Old Dec 13, 2006 | 11:45 PM
thunder550's Avatar
High on diesel fumes
Default Fuel pressure sensor with stock rails?
Anyone running a fuel pressure gauge with stock fuel rails? Where did you put the sender?
Old Dec 14, 2006 | 12:04 AM
nonnieselman's Avatar
Im wondering the same thing... im goin to need one before i put this turbo thingy on.
Old Dec 14, 2006 | 12:42 AM
blacksheep's Avatar
You can screw a 4an fitting on to the test port on the fuel rail. Just get 4an female fitting that has a 1/8" npt port on it so that you can screw the fuel sender into it.
Old Dec 14, 2006 | 12:50 AM
2004SSS's Avatar
werd dont forget to remove the shrader valve.
Old Dec 14, 2006 | 01:17 AM
Wilde Racing's Avatar
How do I change this text
Old Dec 14, 2006 | 01:40 AM
thunder550's Avatar
Thanks Dusty!
Old Dec 14, 2006 | 01:56 AM
Originally Posted by thunder550
Thanks Dusty!
You mean that crappy picture actually helped? Cool
Old Dec 14, 2006 | 08:23 AM
thunder550's Avatar
Yep I had to stare for a minute to figure out why you posted that pic, then I saw the purple and black wire, and went AHA!!
Old Dec 14, 2006 | 09:19 AM
hourang's Avatar
yeah remove the shrader valve, and put it there. i have my fuel pressure safety switch and fuel line for the wet kit there.
Old Dec 14, 2006 | 04:20 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
