Fuel pressure low...
Old May 30, 2010 | 08:48 PM
5.3 GMC's Avatar
Default Fuel pressure low...
At idle my fuel pressure is 44 and only 52 at wot. Walbro 255 in tank is brand new. What can I do to get it back where I need it?
Old May 30, 2010 | 09:02 PM
53bowtie's Avatar
Have you changed the fuel filter in a while?? Also might run some cleaner though in the next tank of gas.
Old May 30, 2010 | 09:26 PM
5.3 GMC's Avatar
It's gettin changed tomorrow although it doesn't have more than 10k miles on the one in it now.
Old May 30, 2010 | 09:53 PM
rmck490's Avatar
If that's not it, maybe the fuel pressure relief valve.
Old May 31, 2010 | 11:11 AM
5.3 GMC's Avatar
Where is the fuel pressure relief valve located?
Old May 31, 2010 | 11:46 AM
rmck490's Avatar
I meant the fuel pressure regulator actually. I hope that didn't confuse you. It would be on the fuel rail on the driver's side of the motor.
Old May 31, 2010 | 05:04 PM
5.3 GMC's Avatar
Well I changed the fuel filter today and it's still the same. I guess a regulator is next
Old May 31, 2010 | 10:25 PM
53bowtie's Avatar
If you have a gauge to put on the fuel rail you can disconnect the vacuume hose on the top of the fuel pressure regulator and the pressure should go up to 70 ish. Then you know it is the regulator that it bringing it down to the level its at. Also, the regulator could be leaking if the vacuume hose is wet although this normally will make it flood a little not drop pressure.
Old Jun 1, 2010 | 02:30 PM
5.3 GMC's Avatar
Swapped out the regulator and got it back up. 52 at idle and 58-60 at wot
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
