Fuel pressure issues?
Old Nov 2, 2015 | 03:24 PM
MikeD.'s Avatar
Default Fuel pressure issues?
So I had a question about fuel pressure. 2006 Sierra that I upgraded to a Walbro 255 (gss340). Started having some starting issues, cold start would be funny, and hot starts would have to cycle the key twice to start decent. So I put a fuel pressure gauge on it today, and as I expected, it will not even hold pressure during the prime. Jumps to 58/60psi, and bleeds off almost instantly. So I know there's an issue there. With the engine running, it holds a steady 58/60psi, but at WOT is drops a couple psi to about 54ish. Is the wot fuel pressure normal? I assumed at wot is would increase in pressure not decrease. Or maybe I'm wrong. Anyway, I know I need to pull the pump and see why it's bleeding off, but just wondering if the wot pressure is right? Thanks guys
Old Nov 2, 2015 | 07:01 PM
Vortec350ss's Avatar
The returnless systems tend to decrease pressure at heavy throttle... its far from ideal.
As far as the start up issues it seems to point to a regulator problem I would think but I cant say for sure.
Brandonlflr12
Oct 9, 2015 12:29 AM
flatblack83
Oct 8, 2015 04:45 PM
pewter00
Oct 6, 2015 06:37 PM
mhorn0817
Oct 6, 2015 11:00 AM
Velocity1
Oct 6, 2015 02:42 AM
