Fuel Pressure Guage Install
Old Nov 26, 2005 | 09:07 AM
WaitinToDrag's Avatar
Default Fuel Pressure Guage Install
I've got the Autometer Electric Fuel Pressure Guage and I just got the adapter from Autometer. Part # 3028- 1/16" NPT Male to 1/8" NPT Femail adapter for fuel rail.
So, heres my question. I'm pretty sure of the answers..but just wanna be positive.
Do I just unscrew the Fuel Check valve off the fuel rail and screw in the adapter fitting? Of course I'll wrap them both in teflon tape. Should I bleed the fuel pressure? Or just have a big towel ready?
Thanks,
Chris
Old Nov 26, 2005 | 09:12 AM
ranwalk's Avatar
Bleed off fuel pressure and remove the shrader valve from inside the fuel stem. I would have some towels under it to catch any excess fuel.
Old Nov 26, 2005 | 09:31 AM
this adapter looks like it screws directly into the furl rail
Old Nov 26, 2005 | 09:44 AM
Mort's Avatar
Cool
It probably does. Just take the cap off the fuel rail bleeder, bleed off the pressure with an old rag underneath to catch any fuel that comes out and remove the shrader valve as suggested by ranwalk. The valve is in the fuel rail crossover pipe on the passenger side of the engine. I think ranwalk is referring to the same valve that you are.
Old Nov 26, 2005 | 09:47 AM
ranwalk's Avatar
It would have to screw over the fuel rail, I dont think they offer one that will work with our trucks. I had to have one fabbed up for mine.
Old Nov 26, 2005 | 09:50 AM
its the one on the right. the sender unit screws into the bottom side
Old Nov 26, 2005 | 10:24 AM
Mort's Avatar
Cool
The adapter on mine screws over as well and I got the fitting from Dynotune. It has a cap on the end so I can still use it to relieve fuel rail pressure without removing the fitting and the guage fitting screws into the side of it. Ranwalk may be correct about the threads on the fitting you have they may not be correct.
Old Nov 26, 2005 | 11:04 AM
1TRUESS's Avatar
would like to see pic when it is all done!
Old Nov 26, 2005 | 11:10 AM
ranwalk's Avatar
That fitting will not work. You will need an adapter with a female end on both sides. You will have to fab somthing up using a couple of different fittings. I will try and get some pics of mine when I get off work today and post them.
Old Nov 26, 2005 | 12:40 PM
thunder550's Avatar
High on diesel fumes
Here be mine, I didn't use an adapter, just screwed directly into the Radix fuel rail. Has work great for over a year. I had a rag ready when I did mine, but if you let the truck sit for awhile the pressure should bleed off on it's own. I got very little leakage, much less than I was expecting. Mine is Autometer also, so unless they changed their senders yours should work exactly the same. This is on the driver side, not the passenger, near the front of the rail. There was a little cap there that I removed, same thread as the sender. Very simple.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
