Fu&%ing VE TUNING, WILL COMMIT HOMICIDE!!
Old Feb 8, 2005 | 10:28 AM
marc_w's Avatar
Originally Posted by TurboBerserker
Edit uses raw VE. HPT uses VE%.
I totally forgot about that....
Old Feb 8, 2005 | 10:33 AM
marc_w's Avatar
Originally Posted by CRAZYCUTER4.8
SO AM i SCREWED OR WHAT?
Nope... Unfortunately, I really can't spend too much time on here - I think the best bet is to try the PCM/Tuning section. What you have happening isn't uncommon, I just don't know the fix. Tell them that you're trying to do a SD tune, and you can't run off of your base VE table when the MAF is disabled.
They should also be able to help you do a SD tune using your software - I know there are others out there using it.
Everything else for the SD tune should work for you (like disabling MAF and closed loop operation)... I just thing that it's a little harder without the VE table already calculated out to a percentage, and the lack of a histogram with STFT and LTFT data.
With the VE in 'raw' form I don't believe the quick and easy copy and paste method will work.
You'll have to make "blind" changes to your VE and see how the logged data responds.
Old Feb 8, 2005 | 12:09 PM
14 Second Truck Club
Blake, get a freakin' dyno tune from one of the sponsers or at least a mail-order tune and tweak it! After you get it figured out, get some dyno #s and track times, I'm curious to see what that cam will do in a 4.8.
Old Feb 8, 2005 | 01:04 PM
I am probably real close on the power enrichment tune richard, I would say other than seeing how much less timimng this larger cam likes. As for the fueling I am a tad of fduring SOME part throttle driving, I have a tendancy of overcompensating fuel @ part throttle low load driving.
As for what it will do? You really need take a ride with me, nasty is all I can say!!!
Old Feb 8, 2005 | 08:30 PM
Ryan23silverado's Avatar
you are lifting a lot on ZO6 valve springs
I will give SD tuning a try when I get some time. I really hope you can get things nailed soon. Driving with a big cam and sub par tune is a Huge pain.
Old Feb 8, 2005 | 08:53 PM
I might have to come by the dealership in a couple of days! I'm really curious to see how that cam pulls. Did you install that TCI SSF 3500 yet?
Old Feb 9, 2005 | 08:46 AM
waiting on brads lift to free up, already paid, I hope by this weekend. It sitting in my garage is driving me nuts!
D3moN plz
19
Dec 9, 2015 11:14 PM
06 4.8
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
Ls3silverado
Jul 31, 2015 04:22 PM
oharajo
Jul 18, 2015 09:24 PM
