Frustrated Radix Tune!!! PLs Help!
#31
Where are the cam sensors on these trucks? Maybe when the supercharger went on the sensor may have been damaged, I only saw misfire codes after a cam install on my LS1. I also broke the oil sending unit due to it being behind the manifold where I could not see it. Could happen to anyone.
#32
Originally Posted by BlownChevy
I would leave the truck the way it is and put our tune back in.
a PO300 code is a random missfire, not a pinging code.....we need to figure out what is causeing that code.
First step in troubleshooting is to go back to a known good condition.
#33
Originally Posted by dhpro
2 latter being servo/shift kit and LT's. Now they are saying they can't support a tune for the LT's!!! Already changed the wires to MSD 8.5's and NGK plugs. Installer is experienced shop - altho mostly BMW race cars - but has some some Vette's and SS trucks. Install has been rechecked with Mag a few times and we're all sure that not the prob. Several posts at other sites suggest that Radix & Lt don't mix. R/
#34
You need to look at your current misfires and misfire history for each cylinder. I bet you'll see one cylinder thats causing your misfire problem. Replace that plug or plug wire and see if it cures your issue. (I bet it does) If you don't already have a set of colder spark plugs (NGK TR6), then this is a good time to install some.
I'm running long tubes with a radix and have no issue with tuning. BUT, in the past, I hit a plug with the header during the install and started getting a 300 code and flashing SES light. I replaced the plug and bingo, back in business. I've also broken two plug wires when pulling them off the plug during a plug change.
#35
no need for that at this point....we need to get back to what he started with.
#36
#37
All wires & plugs have been changed and rechecked since. I'll recheck plugs again to be certain, but if it was any of these mech issues, then I'd get the same misfire code with my Nelson tune installed as well. The code only happens with the Mag tune installed on the OEM PCM. R/
#38
Originally Posted by dewmanshu
as I said keep it simple...you said mag would take back the unit right?...then send back the unit you have and get a new uniiiii...wait a minute...so what was your problem with Allen's tune then if you have no codes on his? Oh yeh, nothing down low. But to get something down low you have to settle for the 0300 code on the mag tune. Hmmm. What was Allen's take? And Allen certainly should be able to fix the "down low".
#39
#40
Neither one had the down low power, but its been mid 90's and very humid, so that cud be the prob there. No code on Allen's, only with Mag's. R/
