Frustrated Radix Tune!!! PLs Help!
Old Jul 25, 2005 | 02:03 PM
  #21
dhpro's Avatar
Originally Posted by dewmanshu
I had a misfire in the beginning...it was a cracked plug. Worked under intense load but under 3K it would take a crap here and there. LOL, you haven't seen the half of it yet...you'll probably start throwing 1153 and other heater codes (135, ect) soon as well with those LT's.
I definitely don't see the radix being the culprit for a misfire as well....especially a random misfire code. I am not so sure about a tune either. All do respect to jesse and allen, but those tunes are pretty cookie cutter to some extent. But, never say never...have had my tune isssues before (my own...not Allen's or Jesse's).
Experienced mechanic, double checked everything, Magnus not supporting LT's. What did Allen say about the P0300? So you didn't get your code until Allen's tune?How quick did you install Allen's update to the PCM after your superchips install?
If it's not simple it's usually cam related...but you didn't mention a cam. And only 6psi...hmmmm...
300 code was using the Mag Superchip. Nelson's hasn't been a prob except he didn't code my vin so its tough to start and still no power off the line...R/
Old Jul 25, 2005 | 03:29 PM
  #22
BlownChevy's Avatar
blownerator
25 Year Member
a tune would not cause a po300 code to be logged. I would suggest going through the entire install, blower, headers, everything and go from there. I would also suggest putting the Magnuson supplied tune back in and trouble shoot from there.
Old Jul 25, 2005 | 03:57 PM
  #23
moregrip's Avatar
what a rush!
Thats one thing cool about Radix owners, they all seem to care enough to help
Old Jul 25, 2005 | 03:59 PM
  #24
OCBC's Avatar
I got that code when I installed my tune. I talked to the tuner and they said that some truck in 04 were extremely sensitive to that code. He adjusted the tune or cleared the code and it works fine now.
I have no idea if he was feeding my BS or not. I am just reporting what I told.
Old Jul 25, 2005 | 04:01 PM
  #25
dhpro's Avatar
I guess Mag will have to do something if I do that. they have basically already said its not their tune, and I'm welcome to send the whole unit back. Is that ur suggestion then? R/
Old Jul 25, 2005 | 04:11 PM
  #26
BlownChevy's Avatar
blownerator
25 Year Member
No, my suggestion is to start over from scratch with the Magnuson supplied tune and trouble shoot from there. I still feel that you are having some installer error issues somplace.
Old Jul 25, 2005 | 04:59 PM
  #27
wkdivr's Avatar
I agree with blownchevy, eliminate as many variables as possible. Start with the Mag supplied tune on a stock pcm. I know this sounds like a lot of bullshit, but is it possible to put your stock exhaust back on to see how the Radix works with no other additions?
Old Jul 25, 2005 | 05:09 PM
  #28
BlownChevy's Avatar
blownerator
25 Year Member
I would leave the truck the way it is and put our tune back in.
a PO300 code is a random missfire, not a pinging code.....we need to figure out what is causeing that code.
Old Jul 25, 2005 | 05:16 PM
  #29
wkdivr's Avatar
What about a cps relearn?
Old Jul 25, 2005 | 05:17 PM
  #30
BlownChevy's Avatar
blownerator
25 Year Member
no need for that at this point....we need to get back to what he started with.
