Frustrated with new 1/4 time
Old Aug 12, 2004 | 12:33 PM
Last Call's Avatar
TOTM: January 2007
Default Frustrated with new 1/4 time
Back in May with just the radix (3.6 pulley) I ran a 14.099 @ 95.59 with a 2.089 60'. The conditions were 66 outside, humidity 75, and barometer 29.70. Last night, with a 3.4 pulley, TOG's headers, magnaflow muffler, and ET streets. I ran a best 14.135 @ 97.22 mph with 2.117 60'. Conditions were 80 outside, humidity 50, and barometer 30.05. I'm pretty pissed because I thought I would finally be in the 13's. I'm hoping it has something to do with the heat. What do you guys think the problem is? I see about 6lbs of boost with the 3.4 pulley.
Old Aug 12, 2004 | 12:39 PM
I have heard that when you put headers on you have to run a smaller pully just to get the same boost that you had before.
Old Aug 12, 2004 | 12:40 PM
onyx's Avatar
14 Second Truck Club
heat also is a very nasty factor......
Old Aug 12, 2004 | 12:56 PM
Black Blown 02's Avatar
The DA difference should be about 700 feet. That's about 3% less air, which is maybe 1-2/10'ths and 1-2 mph slower.
You really have to look at the mph. ET depends too much on traction. You gained over 1.5 mph and if DA was the same, you would have gained around 3 mph.
With the same 60' and same DA, you'd have ran a 13.8 or so.
Old Aug 12, 2004 | 01:02 PM
onyx's Avatar
look at it this way... with everything in my sig fastest ive ran is a 14.9... Tucson is 3,000 above sea level, and at night when we run, its about 85 degrees... now THAT is a big downer.... plus its monsoon season in the summer, so we have humidity mixing in with the heat... its a time killer...
Old Aug 12, 2004 | 03:45 PM
Last Call's Avatar
TOTM: January 2007
I guess I just need the 3 inch pulley. Maybe that will get me there. Probably should have done that first. Not sure how much the headers and magnaflow exhaust helped.
Old Aug 12, 2004 | 04:04 PM
Blackbird's Avatar
look at your 60'
get that back down and your in the 13's. Your mph went up, your making more power, just get it to the ground faster.
Old Aug 12, 2004 | 04:29 PM
zippy's Avatar
looks like a little higher stall would make a huge difference in your truck.
Old Aug 12, 2004 | 06:37 PM
shandy294's Avatar
That's the one and only track I've ever run at...waaaaayy back in 71...71 Demon 340...if I could've left with the Roadrunner,I would've got a trophy.
Oobray
Jun 13, 2022 03:38 AM
chevy6.0fan
Aug 20, 2015 07:10 PM
fastjweb
Aug 15, 2015 10:47 AM
Bluchevypick
Aug 8, 2015 10:35 AM
fcompean
Jul 15, 2015 09:55 PM
