Free Performance Mods
Old May 17, 2006 | 06:36 PM
TIM Z's Avatar
11 sec. Truck Mod
what size coupling do you guys use for the TB bypass?-Thanks
Old May 17, 2006 | 06:50 PM
The stock hosing that comes out of the radiator is actually long enough to reach the entire distance... so you can just toss the second hose.
Old May 17, 2006 | 06:54 PM
TIM Z's Avatar
11 sec. Truck Mod
thanks, Dam it doesnt get any cheaper than that boys!
Old May 17, 2006 | 07:32 PM
are yall capping the barbs on the throttle body when you bypass it?
Old May 17, 2006 | 07:39 PM
EvilChevy's Avatar
YES with Vacume caps and De-screening the MAF Helped me a lot i just have to make sure the K&N isn't over oiled.. IF you do DE-screen just keet a can of electrical contact cleaner handy all the time
Old May 17, 2006 | 07:49 PM
BigBlockChev572's Avatar
Why cap it? No part of it goes in the throttle body, so there's no vacuum leak. The screen on the MAF is so that the sensors read a "straight" airflow, not a curved which is an incorrect reading. Don't descreen it.
Old May 17, 2006 | 09:51 PM
stone150's Avatar
half shaft the throttle body
what does thaat mean?
also how much coolant comes out then you do the bypass?
Old May 17, 2006 | 10:24 PM
TXsilverado's Avatar
all throttle body mods mentioned above can be found here...
http://www.geocities.com/wilwaxu/throttlebody.html
i used vice grips to pinch both sides of the coolant lines to prevent any major losses of coolant
Old May 17, 2006 | 10:54 PM
most people with te TB mods spend quite a bit of time porting it all so alot of times the gains are all in their head. if you do the bypass, you shouldnt lose much if any coolant as long as your engine is cold. if you live somewhere its very cold i do not recommend doing the bypass at all or in the winter your TB could freeze
Old May 17, 2006 | 10:57 PM
GoldenVelvet's Avatar
I have a de screened MAF that I will trade for a un molested MAF.
