Found out some info on L92 exhaust
So I called Corsa to ask if their cat-back systems are made out of platinum; they claim they are not. The kit for my truck is $1100
. The factory exhaust is 3.5" from manifold to tip. Corsa claims the stock pipe reduces before the muffler to only 2.25" and then back to 3.5" after. I can not see this reduction so I guess I can neither confirm nor deny. Does this make sense to anybody?
Corsa said they get better #'s by using 3" throughout on their system, 12 hp and 16 ft. lbs. at wheels. Thats pretty weak for $1100
. The factory exhaust is 3.5" from manifold to tip. Corsa claims the stock pipe reduces before the muffler to only 2.25" and then back to 3.5" after. I can not see this reduction so I guess I can neither confirm nor deny. Does this make sense to anybody? Corsa said they get better #'s by using 3" throughout on their system, 12 hp and 16 ft. lbs. at wheels. Thats pretty weak for $1100
That's surprising. I just bid on a 3" corsa single in dual out on e-bay. It's off of an f-body but I'm pretty sure I can make it work (master welder). Hopefully I can get kooks to hurry up w/ the longtubes for these trucks.
id just change the muffler and leave the rest alone. Most of the cat backs on the market are way overpriced, when the only thing you really need to change is the muffler itself. thats the most restrictive part.
GMCtrk
38
Aug 9, 2015 08:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
gtyler04
Jul 28, 2015 06:21 PM
