Found a loose ground wire the other day
Old Mar 5, 2010 | 12:08 PM
00ChevyScott's Avatar
Wearin' da big hat
Default Found a loose ground wire the other day
Must have not been hooked up since I swapped out motors over a year ago. Never had any check engine lights or anything weird happening, but I hooked i up anyways. I'm just wondering what it was for now.
It was 2 black small gauge wires (14 gauge estimate) that come out of the wire that runs to the red jump box. The ground location is meant to be with or around the main ground coming from the negative battery post to the block. I traced where the wires went the best I could and went up somewhere near the starter/oil level sensor/crank sensor, but couldn't really tell where it went because it was all wrapped up.
Any ideas? I had no check engine light or anything on for over a year with this disconnected.
Old Mar 5, 2010 | 12:25 PM
charcold-bowtie's Avatar
IIRC i have two small wires that are grounded, using one of the two bolts holding the red box to the front accessory piece of the motor.
Old Mar 5, 2010 | 12:26 PM
nevermind, mine are the fans I added
Old Mar 5, 2010 | 03:17 PM
Mangled03gmc's Avatar
Baltimore Whore
I wouldn 't sweet it. have you ever had the fuse box under the hood out. There are about 20 wires that arn't connected to a thing
Old Mar 5, 2010 | 03:28 PM
lownslo's Avatar
no freaking way you had those loose too! My wife come running out of the house the other day and said hey you go wires hanging down. It was a small ground wire comming from the little box on the neg. battery cable so i grounded it. I never had any problems or anything but that is weird!
Mossyoakglock
Aug 28, 2015 12:49 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
shupe
Aug 5, 2015 06:45 PM
