forged 383 build, afr heads... suburban... lots of pics
Old Sep 15, 2012 | 10:24 AM
  #21
RezinTexas's Avatar
Here are the heads!
Checking to ensure correct combustion chamber volume, 63cc spot on.
  #22
RezinTexas's Avatar
Removing springs for checking PtV. I needed a little help with the valve spring tool for the last click...
New head dowels installed with light tapping.
3 studs installed for PtV checking.
View of exhaust valve interfacing with piston relief.
Measuring PtV. Although this magnetic bridge stand will obviously not hold to the heads, I used firm pressure from my hand to hold it down while I cycled the rocker arm with my other hand. I was able to get repeatable measurements.
Minimum PtV Intake = 0.272" @ 6.5 deg ATDC
Minimum PtV Exhaust = 0.258" @ 7.5 deg BTDC
The above numbers matched my calculated predictions based on measurements of the components prior to install. This chart shows piston valve relief surface position & valve tip position vs TDC.
Starting to look like an engine again!
Old Sep 15, 2012 | 10:27 AM
  #23
RezinTexas's Avatar
Pictures of the swap!
LQ4 coming out:
Setting up 4-point chain rigging on new engine.
Installing new engine.
^ that's RTV on the knock sensor outer grommets, to help them seal out fluids (moisture, oil leaks, etc.)
^ Still have the factory intake for a few months. Going to upgrade to a Tony M fast lsxrt ASAP.
Old Sep 15, 2012 | 11:46 AM
  #24
Ferocity02's Avatar
Very meticulous. Great work!
Old Sep 15, 2012 | 06:30 PM
  #25
silver-mod-o's Avatar
Hunt&Fisherator
Super clean install!! Looks good so far, how's the power?
Old Sep 15, 2012 | 11:30 PM
  #26
swift700's Avatar
Great looking engine you have there. I sure like those heads. I may have missed it but what is the compression ratio? That engine looks to be begging for boost.
Edit: I saw that it's going to be over 11:1. Obviously you are looking to stick with a N/A setup. It will make nice torque none the less. I'd love to see some dyno numbers once it's done.
Old Sep 16, 2012 | 07:34 AM
  #27
RezinTexas's Avatar
thanks for the replies.
Power is much improved over the stock LQ4, however the stock intake and TB is really holding it back. I'm upgrading those ASAP.
Old Sep 16, 2012 | 11:37 AM
  #28
SlickSierra's Avatar
I think you could have a pretty successful side business building ls engines if you wanted lol. Great build
Old Sep 21, 2012 | 04:45 AM
  #29
chevybuilder383's Avatar
Originally Posted by smokeshow
Looks like proper tools and proper technique to me! Takes forever to do that, but man does it give you a nice finished result
It takes forever but less time and money than pulling the engine back out
Old Sep 21, 2012 | 05:40 AM
  #30
rjwz28's Avatar
Man Motor club
Any particular reason you decided to build the 5.3 vs the LQ4?
