Flushed my brakes last night...
Old Jun 25, 2004 | 10:55 AM
Yeah, air is a bad thing.
If you get the ATE Super Blue fluid, flushing the system is very easy (since it really is blue). I sucked out all my fluid in my reservior, then filled with the super blue. Went to the rear opened up one of the bleeders and left it open until I saw blue. Then did the pumping thing to finish getting any possible air out. Did the same for all. Just be sure to keep the reservior full.
Old Jun 25, 2004 | 01:26 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I did the same thing except I used this when I bled my brakes
http://www.gprparts.com/brands/motive/
You suck out all the crappy fluid out of the resevoir, pour a little fresh fluid in, and then hook up the power bleeder to the master cylinder. Pump the power bleeder to get some pressure in there, then bleed the system.
I went passenger rear, then driver rear, passenger front and then driver front last.
2 liters was plenty and even had some left over
Old Jun 25, 2004 | 05:31 PM
marc_w's Avatar
Now that thing is cool.
I had one of those vacuum operated bleeders - I didn't like it a whole lot. It sucked a lot of air passed the threads on the bleeders.
Old Jun 25, 2004 | 05:36 PM
Hit Man X's Avatar
Originally Posted by goshawk23
damn, i need to flush mine then. 100K and never been done. i am dumb when it comes to brakes, i can change them and that is about it. so what all do you do, is there a bleeder thing you buy and hook on the line somewhere? or just unhook it and have your helper keep pushing the break peddle?
Oh man, you'll be suprised how much better you will stop with clean fluid! I was. Hell a shop would charge less than $50 probably to just flush them.
I just got a 5/16" hose and attached it to the bleeder valve and just got all that gross stuff out of there. It took a while but well worth it.
Old Jun 25, 2004 | 07:10 PM
goshawk23's Avatar
Truck addict
i might do this in a week or so. i am about to order some hawk pads and doing the fluid at the same time seems like a good idea to me. thanks for the info
Old Jun 25, 2004 | 08:05 PM
gearheads78's Avatar
Originally Posted by NovaTime
I need to do that this weekend. I just wish I had a power bleeder
One of the best tools I ever made was a pressure bleeder. Take a piece of think plate stock. Drill and tap for 3/8" pipe thread. Install air hose nipple. Cut and glue a piece of rubber gasket material to the back side. Clamp it to the MC with a couple of large C-clamps. Turn pressure down to 5-10 psi and hook up hose.
You now have a poor mans pressure bleeder that works great.
Old Jun 28, 2004 | 09:23 AM
marc_w's Avatar
That's cool, gearhead... I think I'll whip one up soon.
Old Jun 29, 2004 | 08:51 AM
Dirt.boy's Avatar
Default Power bleeder operation?
How does this thing work? I assume it attaches to the master cylinder. But is it make specific or can I use it on all my vehicles?
Thanks
Old Jun 29, 2004 | 02:27 PM
It's make specific. I'll see if I can find which part number it is.
You attach it to the master cylinder and secure it tightly, it comes with a chain and stuff to wrap around the MC. Pump it up and get pressure, then bleed the brakes.
RustyD
May 23, 2016 07:04 PM
drummer0415
11
Oct 24, 2015 08:16 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Alco
Sep 4, 2015 04:08 PM
